Question about Sirius STILETTO 100 MP3 Player
My Stilletto 10 doesn't reliably record programmed talk shows. I leave it on and plugged into my car kit (yes, it is powered by a plug that stays on when the car is off) and when I come back it is sleeping and did not record. Other times it works just fine. ???
Is it set for auto shut down? It took me months to properly record with this thing, frustrating at best. Now it's almost flawless. Go in to menu then settings then dock. In that menu you will see "Auto Shutdown". If this is on, your receiver will shut off after 4 hours only when plugged into the car dock. When on a home dock it will stay on. Turn this off and it will stay on until you shut down. Auto shutdown is the default setting. If for some reason you receiver is reset, you will need to check this setting again, because it will turn auto shutdown on again. Hope this helps.
Posted on Sep 14, 2009
It says no info on the programs I want to record and won't record them. The guide also shows no info in those areas.
Janette578,
Make sure the receiver is powered off each night so it can receive updates through the satellite to the guide.
You can force a guide download by unplugging the receiver for 10 seconds and plugging it back in. If that doesn't work, you can run a check switch test from Menu > System Setup > Installation > Point Dish > Check Switch > Test. Let it finish, then exit out of the menu and let it acquire signal and download the guide.
If you have any other questions, or need further assistance, let me know!
Tommy Faust
DISH Social Media Representative
Oct 22, 2012 | DISH Network ViP622 DVR DTV Receiver /...
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
We purchased a jvc DRMV150 dvd/vcr combo about a year ago, since then, no problems, Until Now! :( First, only just a few weeks ago, it will not stay powered on, after any timer recording has just got...
About a year ago still gives you full UK free guarantee rights (if you're in the UK but similar rights operate elsewhere) and JVC aren't the ones to haggle about a few days (or more) over the date.
Get it straight back to where you bought it first.
They have to do the rest.
Just before that try pulling the AC plug of the unit out and leave it like that for 10 minutes or so then plug back in, switch on and see whats happening then.
Sep 22, 2011 | JVC DR-MV150B DVD Recorder/VCR
When pressing power on button, power light comes on for 5-10 seconds, then goes off. Will not stay powered up....
Hi t53doc,this is Mike Houston of DISH Network I was reading over your post and see wherethe receiver will not stay powered on. Please unplug the receiver for 10 seconds andthen make sure the receiver is plugged directly into the wall. It will power upand require the signal and download the program guide. If you have any questionsI will leave my e-mail michael.houston@dishnetwork.I will leave a link to help with these steps. http://www.dishnetwork.com/SupportSection/receiver-no-power
Mar 27, 2011 | DISH Network 301 DTV Receiver
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
How do I transfer stilletto 2 files to PC
Run the audio out from the stilletto headphone jack or dock to you PC's microphone port and record into sound recorder. Only current way to bypass its DRM.
Jan 03, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
NO VIDEO FIRST THING IN MORN GREEN LIGHT ON/OFF
hi zackmann37! I will be glad to assist you on this issue. 1st lets try to isolate the problem, unplug the power of you dvr receiver from the power strip or surge protector and leave it unplug for 1min. after 1min, plug in directly to the power outlet not on the power strip or surge protector. Why? some of the power strip does not give the 100% current needed by the dvr system thats why its malfunctioning, it gives the 100% power voltage but not the 100% current. then let the dvr reboot by itself once its rebooting you will see attention 015 then it will go on a progress until it download the programming guide and you got you tv shows, observe it until the next morning, leave the dvr plug in directly to the wall, now before you sleep, turn off the receiver by pressing the power buttonon the remote to turn off the green light. once you wake up in the morning, press the power button and the green light and the amber light will turn on and it will show your program, but if the problem still exist, you need to call on 1-800-333-3474 talk to dish tech support and tell them that you need a replacement receiver, you have a dvr lost of function. pls feel free to get in touch if you have any query
Sep 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
We have an Olympus Digital Voice Recorder VN-3100PC and it will not power up with new batteries installed correctly. When a power line is connected into the "PCI/F" connector it flashes "CHK" then stays...
when the recorder is plugged into the pc, it will flash pc and be powered by the pc... but when the recorder is not plugged in, then the batteries are needed to power on
Jan 18, 2009 | Olympus VN-3100PC Digital Voice Recorder
SL 100 keeps restarting. Computer does not see it when it's hooked up.
I had to re-install Version 1.1 of My Sirius Studio from original CD that came with my Stilletto 100 as the most recent Version of My Sirius Studio did not recognize my Stilletto when I plugged the USB into my PC, when I re-installed Version 1.1 over the newer version, I shut down the Stilletto by holding down the power swith for 5 seconds then powered back up while holding down the Options and Display buttons at same time until the screen asked me to plug the USB cable into PC to recover. I did this and about 5 minutes later the the software/firmware was re-installed in my SL 100. I then plugged SL 100 into antenna and selected satellite radio, took about 1 minute to re-aquire the station ID's and Icons then I selected Sirius Hits 1 then everythings was back to normal, other than I lost all of my stored songs and recordings, but at least my SL 100 is operational again.
Jul 20, 2008 | Sirius STILETTO 100 MP3 Player
My computer doesn`t see my mp3
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Mar 31, 2008 | SanDisk Sansa Clip MP3 Player
Sirius STILETTO 100 MP3 Player Logo
163 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
