Question about Dometic Rooftop RV Air Conditioner
Temp sensor where do i find the temp sensor for a/c
  • Dometic Master
  • 6,674 Answers
Look for little probe sticking out into return air duct area, beside controls. Usually visible when you take filters off. About 2-3" long and 3/16" in diameter, attached to small brass tube.
Posted on Jul 18, 2009
Is the cylnder head temp sensor and the cooliant temp sensor the same thing on a 2004 Lincoln ls 6 cyndler? Can't find the cooliant temp sensor everything redirects to cylnder head temp sensor even at...
cylinder head temp sensor measures the temp of the cylinder head metal itself and the coolant sensor measures the temp of the coolant only. the coolant sensor is mounted in the coolant and the head sensor is mounted only in the metal of the head and not into anything else. check with a dealer.
Feb 27, 2015 | Lincoln Cars & Trucks
How to replace temperature sensor
There are 4 or more. Which do you want to replace? The coolant temp sensor for the dash? The coolant temp sensor for the ECU? The temp sensor for the outside temp reading? The temp sensor for the fans to turn on? Temp sensor for the AC?
Jul 14, 2014 | 2000 Chrysler Grand Voyager
Where is the temp sensor located and is it easily replaced?
There will two type of sensor, both are located on the upper thermostat housing, one is a sending unit, the other is temp sensor,if you pull one sensor and the temp gauge suddenly drop that is your temp sending unit.If you pull the other one and the vehicle kicks a high idle on and check engine light appears then you have the temp sensor
Apr 21, 2011 | 1994 Toyota Pickup
2000 bettle 1.9L turbo will only start if you unplug coolant temp sensor
Hello and welcome to FixYa!
If that's the case, I strongly suggest that you replace the coolant temp sensor. Looks like it's faulty and grounding the circuit. The car's computer can detect it that's why it won't start but once you disconnect it, it will for the coolant sensor is bypassed.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 14, 2011 | 2000 Volkswagen Beetle
I got stuck in the snow yesterday and now my check engine light is on. im getting codes p0710 and p0711. does this mean the sensor is bad?
P0710 TRANSMISSION FLUID TEMP. SENSOR MALFUNCTION
P0711 TRANSMISSION FLUID TEMP. CIRCUIT RANGE/PERFORMANCE PROBLEM
P0710 DTC Detection Condition:
Either (a) or (b) is detected for 0.5 sec. or more: (1 trip detection logic)
(c) Temp. sensor resistance is less than 79 W
(d) After engine has been operating for 15 min. or more, resistance at temp. sensor is more than 156 kW
Trouble Area:
1. Open or short in ATF temp. sensor
2. ATF temp. sensor
3. ECM
P0711 DTC Detection Condition:
Both (a) and (b) are detected: (2 trip detection logic)
(a) After 12 sec. of engine start, temp. of atmosphere and that of engine coolant is more than -10°C
(b) After normal driving for over 20 min. and 10 km, ATF temp. is less than 10°C
Trouble Area:
1. Open in ATF temp. sensor
2. ATF temp. sensor
3. ECM
Feb 22, 2011 | 1997 Saturn SL
Getting a low coolant temp code.temp is normal. im
Sometimes there are two Temp sensors. Did you see if you had two?
Jul 29, 2009 | 1997 Toyota Tacoma
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Temp gauge off charts
Are you mistaking the engine temp sensor for the engine temp sending unit? The temp sensor is for the fuel injection system and the temp sending unit is for the gauge. If you asked for a sensor thats what they sold you. You need to ask for a sending unit.
Dec 18, 2008 | 2005 Chevrolet Cavalier
Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Sep 26, 2008 | 1998 Chevrolet Cavalier
Temp Sensor
The temp sensor known as the engine coolant temp. sensor tells the computer if the engine is overheating and so forth and tells the injectors how much fuel to give the engine. The temp. sending unit is what controls what your guage reads. It sounds like you need the temp. sending unit. It located near the thermostat housing with a single pole connector.
Jun 18, 2008 | 2004 Chevrolet Impala
Dometic Rooftop RV Air Conditioner Logo
361 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
