My Nelson Turf EZ Pro Jr. Irrigation system, serie 6200, is not shutting off after the programmed cycles.
I tried to reset to factory defaults, but the system locked up. I then used the reset process as described in the manual. This worked, and I reprogrammed, but the problem remains.
The owner's manual states "Er2" indicates the controller has more then 24hrs of runtime programed. Solution; Review your total run times on all programs and correct -OR- Press reset and select + at the same time to return to factory default settings.
if you have 24 Volts AC on solenoid and the valve does not open, but opens manually, then the valve diaphragm is bad. You can test this by swapping wire at timer with a known good one. If the known good one will not open valve, repair it or better replace it.. I have found that buying a new valve and swapping parts is cheaper than buying individual parts. If you decide to replace diagram when reinstalling screws place screw in hole and turn to left, you will feel screw rise up and then fall, this is position you need to in as the screw will back in the original threads and not cut ones. do not tighten screw fully down and repeat for the remain 5 and the tighten in criss cross pattern
Click on the link below and scroll down the page to near the bottom, and you will find instructions to do a "partial reset" , which returns the printer to factory defaults. If you click on the support link at the top of the page and select "support and troubleshooting" you can find a wealth of additional troubleshooting info.
Are you having power blinks? A real problem in my area. If so, replace the lithium battery inside. A little more hassle to get to than the AA batteries (but not impossible), but quite possibly the problem.
Please try the following solutions and keep your fingure crossed:
1. Conect the printer directly to the wall outlet
2. Power cycle:
Follow the steps below to power cycle your all-in-one: 1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet. 2. Wait 30 seconds. 3. Plug in the power cable to All-in-One and also to wall outlet. and check the functionality.
3. Semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal" Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
Look for a 'master reset' in the manual. This should put everything back to 'default setting'. Then start over in your programming. Don't forget to save after you program your parameters.
