I have a HP dc7100 ssf PC...I have added a CD writer, by replacing the original CD-ROM...plugged in both the 4 prong power plug, and the ide strip...MASTER...jumper on the back is set in CS position.....un it driver is working fine...unit burns to disc...but discs don't place back...on any machine...this includes both music and photo files..??
  • 13,433 Answers
I would personally sent the drive on the end of the cable to master and the drive if there is one, on the middle to slave.
If your music and photo files don't play, what program did you burn them with? if you burn a audio disc you can't add photos into it, that kind of disc will only open up on a computer.
you can use nero burning rom software that should have came with the drive to burn audio cd, thats only audio and a photo cd thats only photos or maybe a few videos also.
if you combine the two, its only going to work on a computer.
Posted on Jul 17, 2009
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
Finished CD's are empty...No sound or images
Try playing the CD in another player, if it plays OK, than you have narrowed it down to a problem with your PC. If this drive had a wire that plugged into the main board than chances are you need to do the same thing.
Jul 16, 2009 | HP Compaq dc7100 PC Desktop
Won't reconize DVD burner
Well, the CD ribon cable goes into the IDE 2 slot on the Mainboard and the furthest connector on the other end is the master, the second one closest to the board is the Slave connector. The CD drive has a jumper on the back between where the ribbon and the power connector go, on the case some where it should have a diagram showing the jumper setting to put it in as master or slave. Set it accordingly.
Same with Hard drives.
If the Hard drive has a diferent Cable like a SATA, then be sure to get a SATA as the new one.
Now the IDE cables may be bad check them for damage just to be on the safe side.
Feb 04, 2009 | HP Compaq dc7100 PC Desktop
Dvd/cd writer, and dvd rom drive does not work
Check if you have both cables attached to the CD/DVD drive. There are usually 2 that needs to be connected: the SATA or IDE (that ribbon-like connector that goes right to the motherboard), and the power supply (a connector that has 4 colored lines going to the power box). Make sure they are snug, and if necessary, try changing them with others that are known to work (there should be lots of spares). If the CD/DVD light blinks or powers on upon boot, it means power line is OK, but data cable connection is bad.
Sep 06, 2008 | HP Pavilion (PN153AAR) PC Desktop
Install LITEON 18X Super AllWhiteDVD/CD Writer&Rewriter Serial no 1502-4020-1203-0757-1127-2659
Lost your DVD Writer means ?
Does it stopped working !
Open The cabinet of the CPU and check the IDE Channel
BUS- cable if that is plugged properly.Also check if the Power plug is properly inserted to your DVD Rom,
If both are checked properly, get the lense of the DVD checked in service center. maximum of the CD/DVD problem arises due to damage in the lense. Anyways, The cost of the lense comes to be almost equal to the DVD ROM price  :)
Pease rate if this fixes your problem
May 27, 2008 | Computers & Internet
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
HP dvd rom disabled
if you can open your desktop..try to replace the ide cable of the DVD/Cdrom it might be deffective.before you open your pc just make sure that the power is off.after changing the ide cable of your dvd the system will automatically detect your drive.if you got same problem again try to consult your hardware vendor to claim your warranty parts and service.good luck
Dec 03, 2007 | HP Media Center m7060n PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
