No power going to t.v.
I have a plasma 32" t.v. and it won't turn on the power kick but then shut off?? Don't know what's wrong with it? I also kept flipping the power switch.. It didn't help..
  • 147 Answers
Replace the power pcb.
Posted on Jul 17, 2009
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
May 06, 2012 | Dell Vostro 320 Desktop Computer
Hitachi 55in plasma TV, model 55HDS69. It will not power up from either the remote or the on/off switch on the side. The TV was used a lot, for more than 5 years. It shut off while running. The red...
Hi sir Jim!!!!
kindly check the 5 LED if there is lit lights to diagnose where the fault came from..You said the 5 led turn off for 1 -2 seconds it means no error but still won't turn on I think there sometime wrong on logic circuitry..
Try to read the voltages on highlighted words on picture of block diagram above such as vs,va,vcc,stby+5v,stby+3.3v,+5.5,+10.5 and +12v...
After that let me know the results to diagnose where the fault from..
Hope it helps...
chester..
Jan 19, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Tv was working and then it wasn't. went to turn it on and the power came on briefly and shut off, . won't even show any power lights at all. tried changing power supply no help
Today got a package from Protron. replacement power supply that they sent me free. Problem is they sent one for a pltv32 and mine is a pltv3250, got the wrong one. 32 is external and 3250 is internal
Jun 17, 2011 | Protron PLTV-32 Television
When I hit the power button on my 32" Vizio Plasma
You have a TV with a failing power supply board. There are parts in the power supply called capacitors that start failing and this causes the power supply to not be able to properly filter the voltages. When you keep turning it on and off the capacitors will finally hold a charge correctly so the voltages will stabilize and the TV turns on ok until the next time you turn it off. As time goes by the capacitors will degrade more until the TV will not work any more. If you can solder then you should be able to repair the TV yourself. We have a page on our web site http://www.ccl-la.com/blog/index.php/capacitors/
That explains what capacitors are and how to determine the bad ones that have failed. If you replace the failed capacitors in the power supply then you should have a working TV again.
BuddyMc
Corporate Computer
Dec 15, 2010 | Vizio VP322 32 in. Plasma TV
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
LG 50 plasma
yes that was from that cut power you should go now to the authorized service to fix that problem
Dec 10, 2008 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
