Question about Pioneer PRO-119 60" Rear Projection Television
Does not power on
I have seen very similar problems for other tvs on here, but none really for mine. I turn main power on, get red light. Hit the power on the remote or the standby button, green light comes on. I hear a click and the crts powering. I get a red light on the power supply board. Then it all powers down and back to red light. I can't turn it back on with the stby button/remote. I have to kill Main power then start again.
I am assuming it is shutting down for over current conditions, but I really don't know how to go about isolating things to figure out what part to change. The four fuses I found on the power supply assembly were good.
Thanks for any help.
  • givitup2E Nov 19, 2007
    This is actually for a PRO-118. Very similar to the 119, but I couldn't find that listed on this site for some reason.
    I looked at the power supply board and that was really a mess of a soldering job they did. I can't believe it ever worked.
    Any suggestions on where I could get a refurbished pwr supply. New was like 372. Rather get a better quality piece then what I seem to have.
  • 143 Answers
Ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Posted on Nov 18, 2007
I have a Panasonic KX-T7030 telephone system: the buttons don't work!
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires. This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular (wall) socket you are
plugging the base ('main unit') into.
Apr 24, 2016 | Lands Phones
My LED TV is showing a blank screen. How can I check my TVs backlight by using jumpers on the power board? I've seen videos to do this, but nothing specific to a similar Sony model.
put jumper in between pin no 23 & 28 now your power supply is on but still no voltage at led out put error 6 code is particular for led out put not for t con so please replace power board complete
Nov 02, 2015 | Sony BRAVIA KDL-60EX645
Hi i see you have some knowledge with tvs, and have read your responds to a vizio in a similar condition to mine.. here is the problem, out of the blue one day it does not turn on. However the...
Measure all the voltages present on the power supply board first. If they are all present and within 10% of the normal value, then the main board is suspect. The main board controls the power supply, but if a voltage is missing or out of specs it cannot function correctly.
Apr 15, 2017 | Televison & Video
RCA L37wd12 won't turn on. Red light is on but no reaction from either on button or remote. Used to be able to unplug then replug to fix. Now nothing. I've seen similar posts but no solutions. Any ideas?
This is a power supply problem and they are hard to find because they are not made anymore. I had to replace mine several months ago and it took me a month of research to locate someone who had one.
Dec 14, 2010 | RCA L37WD12 37 in. LCD HDTV
Red power light on our 3-year-old Actiontec router
If the power light is red, it means that the router is already defective.
You can still try to reset the router by pressing the reset button for 10 seconds then power cycle it.
If the power light is still red then you will really need to replace your router.
Jun 15, 2010 | Actiontec GT704WG Wireless Router...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
try looking for your thermistor usually located near the wind path its a small block the size of two match heads usually mounted off the main board with two wires this is your 'heat switch' so to say, also check your fans are clean and running there is normally more than one.
May 15, 2010 | Hitachi ED-X8250 Multimedia Projector
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Mitsubishi WD-60737 will shut off on its own while running on it's own surge protector and it's not overheating
These units had problems with capacitors in the power supply and main boards. Unless you like really hard CHINESE PUZZLES you are best to leave this to a pro.
Oct 12, 2009 | Mitsubishi WD-60737 60 in. HDTV
Polaroid tlx-3210b tv will not turn on the red light comes on and the blue light comes on when you hit the power button but still no picture or sound have to unplug tv to turn off blue light. contacted...
Symptom shows that Mani Board is bad in your TLX-03210B Polaroid TV and need to be replaced. I do not see problem of capacitors in power supply board. Problem seems in system control section of TV that is located on main board.
Click Shop Jimmy as it is best source to obtain boards of LCD TVs.
Please call Shop Jimmy for main board availability as currently its out of stock.
Hit "add a comment" button for further query / info.
Apr 30, 2009 | Televison & Video
Will not come on
Have you try to replace the power supply? I had the same problem with mine then when i took the power supply out I seen that a cap had busted off the solder joint just resolder it back in place and I am using it right now. its been working for 2 months so far
Mar 22, 2009 | Polaroid FLM-2601 Television
Televison & Video Logo
175 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
