Question about HP LaserJet 5100tn Printer
What does 50.2 fuser error mean - HP LaserJet 5100tn Printer
  • HP Master
  • 1,684 Answers
The 50.2 error means your fuser is not heating up. You will need to order either just the fuser HP Part # RG5-7060 or the maintenance kit HP part # Q1860-69002. Check your local computer store or we can ship the parts to you. If you need additional information contact me at our web site below.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
  • 92 Answers
Hi ...
A 50.4 error indicates that the fuser is reporting an error condition. The fuser has a temperature range in which it is designed to operate. If the fuser becomes too hot or fails to attain the correct temperature, a 50.x error will appear on the Control Panel. Troubleshooting this error involves a process of elimination, starting with the most common cause, which is normally directly fuser related. The following can cause 50.4 errors:
  • The fuser experiences a temporary spike in temperature. As a safety feature the DC Controller will trigger the 50.4 error on the Control Panel, and the printer will not print.
  • Printing on some kind of unsupported media. Unsupported transparencies can get wrapped up in the fuser. Once it gets bound up and will not turn, the printer will display a 50.4 error.
  • An issue with the power circuit for the printer can cause a 50.4 error. Any interruption, inconsistency, or lack of sufficient line voltage to the printer can trigger a 50.4 error.
If you are facing this error, please visit the below link and you follow the instructions which will resolve your problem ..
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl12591
Don't forget to vote if this helps ... Cheers :)
  • rajonline Jul 17, 2009
    Hi ...
    http://h20000.www2.hp.com/bizsupport/Tec...
I am getting a 50.2 fuser error on an hp laserjet 5100tn series. How do I fix or clear this problem?
Posted on Jan 26, 2013
    President:
  • 3,278 Answers
Lynda,
A 50.2 error is a Fuser Warmup error. Try these steps:
  1. Verify the power source for the printer is in the wall outlet.
  2. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  3. Try a different power cord. DO NOT use extension cords to plug the printer in.
  4. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  5. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  6. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. WARNING: The fuser may still be hot.
  7. Remove and reseat the fuser.
    1. Turn the printer off and unplug the power cord.
    2. Open the rear door of the printer by pressing inward on two tabs located on the rear door.
    3. Unclip the black strap from the rear door and lay the back door flat.
    4. Locate two screws on the bottom left and right of the fuser and remove them.
    5. Pull the fuser straight out and inspect it for media or other obstructions.
    6. Reinstall the fuser.
    7. Turn the printer back on.
    If still a problem, have the printer serviced.
Hope this helps.
2 Suggested Answers
vladmototole
  • 226 Answers
SOURCE: 50.a fuser error
Change the fuse!!!
Posted on May 21, 2012
Hp 1007 problem fuser error 50
The error 50 code on HP printers usually means a bad fuser unit.
Jul 08, 2015 | HP Office Equipment & Supplies
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
Jun 30, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
50.A FUSER ERROR
The "FUSER" unit uses heat to melt the dry toner-ink into the paper, to permanently lock the ink into place.
So, a "FUSER ERROR" means that it is not heating-up to the required temperate.
Contact your local HP office, and get them to dispatch a service technician to come to your office to make repairs.
Mar 31, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
We have a Canon IR400S with the following error message - Switch main power on & off, E005. Switching power on & off did not clear error. Can you tell me what the error message means?
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
Dec 10, 2009 | Canon Office Equipment & Supplies
I can't print anything, and it says 50 service
This is a fuser error. It means the the fusing unit is not heating up properly. This is the unit that gets hot and fixes the toner onto the paper just before the paper exits the machine. Easy to swap out if you can find a fuser unit.
Good Luck
Nov 22, 2009 | HP LaserJet 4 plus Printer
Error code: 50 service. What does this mean??
Blown quartz fuser lamp. Replacement kit available here for about $40.
Oct 21, 2009 | HP LaserJet 4 plus Printer
Hp 3550 fuser error 50.1 and it is cold.
The fuser error 50 means that the fuser heater lamp is blown and you need to get another one (whole assembly). I personally use printerworks at www.printerworks.com to order a new one if you want to do it yourself, otherwise you will need to drop it off at an HP Authorized repair center..
Good Luck!
Rich Lilja
Jan 09, 2009 | HP Color Laserjet 3550 Printer
ON AN HP LASERJET III PRINTER WHAT IS A '50 SERVICE ERROR'
The 50 SERVICE error means that either the fuser has not warmed up. It can be due to a bad fuser bulb, connections, or the power supply.
Reset the machine by leaving the power off for at least 15 minutes, if the error comes back after turning the printer on, you have parts that need to be replaced.
call an expert from HP to replace the parts :)
Sep 26, 2008 | Office Equipment & Supplies
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 5100tn Printer Logo
3,870 people viewed this question
Seeker5211
Seeker5211
