Question about Toshiba SD C2502 Internal DVD Drive
Sony Vaio, CD/DVD plays DVD's, won't recognize CD's?
This drive will play a movie, but will not let me access any CD's.  When I load a CD (Like the system restore, or driver cd's) and click on drive E, it asks me to please insert a disk into drive E....  The disk is in there-
2 Suggested Answers
SOURCE: dvd drive
This is common problem try to change dvd regions in driver properties to one you are in. I cannot gaurentee you will this work. If not you need to get a dvd that works with your region. Changing regions at your own risk.
Posted on Aug 26, 2007
  • 113 Answers
SOURCE: laptop unable to detect the DVD/CD drive
check device manager? see if there is you drive? check computer managemnt-> storage if you drive is listed.... run add new hardware if not, manual instal with have disk, download new driver, and firmware.
Posted on Apr 30, 2009
0 characters
1 Points
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My cdw/DVD (Sony CRX230E) player will not play movies or home made movie
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 08, 2011 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
I am not able to play my movies recorded dvd but cd is working well, help me,,
Insert a DVD movie.
Open "My Computer".
Right-mouse click on the icon for your CD/DVD drive, and click "Explore".
If the hardware is working correctly, you should see a list of files & folders.
Search online for the free 'VLC' software for playing DVD-movies. Download it, and install it, to "play" your DVD-movie.
Sep 30, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Won,t play dvd on xp pro
Open "My Computer".
Click with the RIGHT mouse-button on the icon for the CD/DVD drive.
Choose 'Explore'.
If your DVD drive is working, some files/folders should be displayed.
Are you using the free 'VLC' software to play your DVD-movie?
If not, search for VLC online, download it, and use it to "play" the movie.
Sep 26, 2010 | Samsung SD 608 (SD-608) Internal DVD Drive
Must sony DDU1615 DVD-ROM be set to region 1 in order to read most DVD Movie on PC. At present it is not set to any region but is hit & miss as to what it will recognize and play. I do not want to...
An easy way to make your computer permanently region free is to install "DVD Region + CSS Free":
Yep, or Any DVD ( from Slysoft, which I've bought. Full price is $40, but it's worth it if you have several DVDs from regions outside of your DVD-ROM. Or you can use VLC (, a freeware media player that will play all DVDs, regardless of region coding. And yes, this is legal. (But it can be buggy)
Nov 26, 2009 | Sony DVD/Blu-ray Drives
Dvd/cd drive device properties state drive is
Apart from DVD, dose it recognize other Cd's? If is does then I think the lens for your drive is weak.
And if it is not the lens, then maybe you should uninstall the drive, restart your system and reinstall the drivers for drive.
You could also detach the drive from your system, while the system is shut down, then put on the system back without the drive, allow it to boot, shut down, put back the drive and see if the drive will play DVD this time.
Best wishes
Nov 10, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
Dec 28, 2007 | LG (GDR8164B) Internal DVD Drive
Vaio dvd drive problems
Trying to play MP3's on Sony VAIO. Music Cracking like it's trying to be solution, sorry.
Nov 28, 2007 | Kingwin Inc. (MS350UBK) DVD Drive
Toshiba SD C2502 Internal DVD Drive Logo
108 people viewed this question
Top Toshiba DVD/Blu-ray Drives Experts
Brian Sullivan
Brian Sullivan
isaac johny
isaac johny
Are you a Toshiba DVD/Blu-ray Drive Expert? Answer questions, earn points and help others
