Question about Desa International RH125AT Utility Heater
No spark i have an ancient 50K btu heater that wont spark. we get fuel and the fan does run but no spark i think we might need an electronic ignitor. Is this part available or is there something else we should be looking at?
  • joe6521 Jul 17, 2009
    it is the rem50
  • lsg2111 May 11, 2010
    What is the model number of your unit? Or do you what the part number is that you need?
    President:
  • 1,922 Answers
If its as ancient as you say it probably has an ignition transformer,open up the unit and isolate the transformer and check primary/secondary transformer windings for continuity,if so then either the electrodes or spark plug thats on the secondary transformer could be defective,be careful POWER OFF secondary can have up to 4,000v.a.c. when plugged in
Posted on Aug 27, 2009
7 flashes no ignitor
Check spark wire if OK bad module
Mar 28, 2014 | Coleman Propane Forced Air Heater...
Wont fire after following start instructions
OK-- Let's go thru your trouble shooting steps, and what you found:
1.) Fuel: Sufficient, and right type?
2.) Has the unit fired and run before?-- What is different in sounds, or settings now?
3.) How does this unit ignite the fuel?-- With Spark, or with Glowing ignitor?
If Spark-- can you hear it sparking?
If Glowing ignitor, -- can you see the glowing? (in a darkened room..)
4.) Can you see that Kerosene is spraying at the nozzle?-- is the pattern correct?
5.) Have you check fuel and air pressure settings-- according to the manual?
After observing these details-- let us know what other clues you are observing now.
I'll be here to take you to the next step, if you like--- Just add your new comments in the 'respond' box-- they will send them to me for further follow-up.
Mack B
Jan 17, 2011 | Mr. Heater Portable Kerosene Heater -...
The heater fan runs for about 5 seconds , does not heat and than turns off.
This could be several problems. Check your fuel first. If it is old fuel from last year, get rid of it and fill with fresh. If it has water in the tank, your spraying water to your ignition source. If you have fresh fuel, it could be a fuel filter stopped up or your air pump is not set properly. Also check your ignitor to see if it is working properly. Some have a spark plug and some have a glow type ignitor.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I left Diesel in my heater all year long i ran it this winter and it stopped how do i fix it
Leaving fuel in heater shouldn't create problems. Check reset, if so equipped to see if there is power, Check ignitor to see if it is firing. Check fuel filter and nozzle screen to see if they are plugged. If you have good fuel spray, good spark at ignitor,and the electric eye can see flame, it should run. If there isn't any spark at the ignitor, the high voltage trandformer could have failed.
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Have a small 35000 btu unit have fuel spray and spark but wont ignite
check to see if the ignitor has not fallen off the back of motor.it's held on by two 2 screws that do vibrate off.if they are on you need to replace the ignition modual.they cost around $80.00 to $100.00
Mar 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Desa International RH125AT Utility Heater Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
