Question about JVC Cybercam GR-DVL520A Mini DV Digital Camcorder
Getting safe mode and error e04 on my 520
Can't get the camcorder to come out of safe mode..also getting the e04 error when I try to put the mini DV tapes back in.when it let me put the tapes back in..motorized compartment where tapes go will not close..just had the heads cleaned recently..so I don't think I have a problem with the heads..anyone have any suggestions..I'm have the sane issue with my 30 too..actual error says eject tape and re-insert..than I get the e04 error..than it will not let re-insert tape and close compartment..
4 Suggested Answers
SOURCE:
kala
  • 156 Answers
SOURCE: not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Posted on Dec 26, 2007
IB4G2008
  • 3587 Answers
SOURCE: Canon zr300 ejects tapes
hmmm...the only reason that usually happens is when the tape is messed up internally, or there is something stuck in amongst the head
Posted on Apr 30, 2008
  • 11 Answers
SOURCE: Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Posted on Sep 09, 2009
Can't get rid of the safe mode. Error 04. Know matter what I do
Are you already try changing tapes, if still try to hairdying the mecanism if you use the same tape after first try turn forward your tape manual, usually the cause of error 4 is the drumhead doesnt spinning cause sticky tape,
Hope this solve your problem
Oct 23, 2013 | JVC Cybercam GR-DVM90 Mini DV Digital...
My camcorder is stuck in safe mode
I need to know more details about your problem, error code follows numeric code. Such as 01, 02, 03 etc. you need to consult an expert. Don't force the mechanism for it will cost you more to repair.
Feb 27, 2010 | JVC GR-DVL500 Mini DV Digital Camcorder
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Error message 06 appearing, I can't clear this eero, please help.
remove the battery for some 1 day and then try .. if you have connected the dc plug into the jack remove that also ....
Feb 11, 2008 | JVC Cybercam GR-D30 Mini DV Digital...
JVC Cybercam GR-DVL520A Mini DV Digital Camcorder Logo
65 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
