Motorcycles Logo
L
Lisa Gibson Posted on Jun 01, 2016
I have a 50cc tao tao scooter. How do I disassemble the piston rings, the oil is blowing out cause the valve is sticking?
5 Related Answers
Anonymous
  • 311 Answers
  • Posted on Jan 04, 2010
SOURCE: Motorcycle knock and blow-by (4 stroke)
hi,might be able to help,a compression test would be a good start,however,if you already have the engine apart,replace the rings anyway,if the engine has been overheated the rings although they look ok will have lost their tension and therefore their ability to hold sufficent pressure against the cylinder walls,therefore allowing blowby,or compression leakage,the other area i would look is the condition of the valve seals and seats,both intake and exhaust,if the engine has been overheated,the seals may have cracked or become weak,whenever i have my race bike apart with the head off i always relap the valves(just a light cut)and this ensures a good seal through the head etc,hope all this helps...cheers ian
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Jul 03, 2011
SOURCE: 15.5 Craftsman riding lawnmower blowing oil/fuel
Hi, drain and change the oil as it has become contaminated with fuel. This is caused by your carby flooding while stored. Check and clean the needle and float in the carby and make sure it stops fuel flow when you hold the float parallel to the carby body. You can also fit an inline fuel tap to prevent this happening again. Hope this helps, regards Phil.
Yush dowlut
  • Posted on Dec 24, 2012
SOURCE: how to pull out pistons on subaru H6 3.0 2002
lack of compression
check the pistons and rings
one or both must be changed
trick1_rm
Tim Rickards
  • 296 Answers
  • Posted on Oct 12, 2014
SOURCE: How to replace the front forks on a Tao Tao Scooters?
Check youtube
jeepguyracin
Bill George
  • 2517 Answers
  • Posted on Aug 20, 2017
SOURCE: What is the cause of back firing on deceleration on a 150cc Tao Tao scooter?
If it is a 4 stroke the valves need adjusted.
1helpful
Is it possible that a 50cc Chinese scooter will continue Spark the spark plug rather than fired at each timing point. As a result rather then start it kicks back on the starter
being a 50cc engine it should have only 1 piston
If it is a 2 stroke , it will fire every time the piston comes to tdc
if it is a 4 stroke it has to have a timing point that excites the ignition system for every 4th stroke tdc
if the exciter receives a signal to fire the plug at the wrong time , it is getting that signal from a fault or incorrect timing
that fault can be
loose wire/s,worn unit that controls the timing ( distributor fault), loose flywheel , flywheel touching coil,incorrect timing (180 degrees out ) stator loose ,rotor loose,faulty crank position sensor
it is good practice to have a workshop manual on hand and if you don't have one go google and type in --workshop manual for 50 cc tao scooter--and see if there is a pdf version in english to download
3answers
Oil keeps blowing out of the dipstick what could be causing this. Thank you
hi.
oil blowing out of dip stick normally means that the engine is getting sump pressure. this is normally caused by wear on the piston rings where the compression of the engine is passing down past the pistons and causing pressure in the sump and then blowing the oil up through the dip stick tube. can also be caused by having a head gasket gone as well as the compression is being blown down through the oil gallery . hope this is helpful to you
1helpful
5.3 blows dipstick out
Sounds like your piston rings are bad causing excessive blow-by ...meaning your power is going around your rings and building massive crank pressure and using your dip stick housing as if it were a pressure relief valve ...motor needs to be rebuilt by an automotive machinist.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
