Question about Apple iPod nano
Songs continue without a break of at least one second or better.How to correct?
Tip
22 .. How do I change songs from an iPod Touch without a pause in between?
<p>While listening to music on an iPod touch device, the transition between songs is often accompanied by a brief pause. Enabling the option of playing without a break for the songs on the device, but you can eliminate this pause, then the songs on the iPod Touch to change, without a pause between them. If you want this feature to connect to your music, you can do in a few easy steps. <br /> <p><br /> <p>1. Connect the iPod Touch to the computer via the USB cable that came with your device and double-click the iTunes application icon to start the program. <br /> <p><br /> <p>2. Click the arrow to the left of the iPod touch under the "Devices" heading in the iTunes window. Click the "Music" option to audio files stored on the device view. <br /> <p><br /> <p>3. Click on the music file first in the list of files stored on the device, hold down the "Shift" key and click the last file in the list of files stored on the device to highlight all the files. <br /> <p><br /> <p>4. Right-click on any of the files and select "Get Info" option from the context menu that appears. Click the "Options" tab to the options of audio files. <br /> <p><br /> <p>5. Place a check next to the "gapless album" option and select the "Yes" from the "gapless album" drop-down menu. <br /> <p><br /> <p>6. Click the "OK" to apply changes to all the songs on the device. Now, the continuous play feature will be enabled for all the songs on the device, so you change songs without a break between them. <br />
on Aug 05, 2011 | Computers & Internet
I made a playlist for a water aerobics class. Is there a way to make it play without breaks between songs?
Checkout VLC player for your phone. It has facility to run playlist without any break.
Oct 04, 2014 | Alcatel One Touch Fierce
Songs are not being played
Hi sandesh_sht4...
Be sure your songs are of the right format to play in your player, otherwise they will not play...
You did not say what kind of player you have, it is impossible to give you a better answer without better info from you.
Bud
Sep 22, 2012 | Audio Players & Recorders
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
Jun 21, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have all 4 Hallmark caroling cottages and cannot get them to do continuous play when connected together
I just read on the Internet that you have to hold the button down for 4 seconds to put it into continuous play mode. There will be approximately 4 minutes (or more, perhaps) between songs when it is in continuous play mode. I read that many people thought continuous play mode didn't work because they didn't know they had to wait so long in between songs.
Nov 28, 2009 | Hallmark Toys
My Ipod classic 80G has stopped playing music. what happens is after I select and then press play it will have the play sign on the top, but the song wont starta and after a few moments it then starts to...
Make sure that you got all of your songs off of itunes, or that they have been converted through itunes correctly. This is caused by songs being the wrong format, or that the song itself is corrupted. Try restoring the unit through itunes, and loading the songs back on. If you are running with your unit while trying to listen music this can also cause the unit to freeze up when playing a song. Any type of continuous motion can cause your ipod to not play songs. This is because the ipod has a hard drive inside of it, and when you move alot with a hard drive it cant read correctly. If you want to run with your unit, i would suggest getting a flash drive based mp3 player (ie itouch). If you have any further questions feel free to contact www.wiredextreme.com.
Nov 14, 2009 | Apple iPod MA446LL/A MP3 Player
Breaks between songs when playing CD's
The musicians union contract demands breaks between songs
Jul 15, 2009 | Toshiba SD4990 DVD Player
Itouch
u may have deleted the source file of the songs and tunes u know wat itunes play songs from d correct destination dat u provide 2 it.............if u changed d location of songs then it is unrecognizeable for itunes for those songs so u better chek if hose songs are playing in ur itunes without relocating the correct source files of ur songs
enjoy
May 30, 2008 | Apple iPhone Smartphone
Apple iPod nano Logo
67 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
