Question about Philips 50P8341 50" Rear Projection Television
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Ok we got this tv its in great shape except the color is mostly red, we went to the color settings on the tv and the only colors you can change it to is blue i mean it doesnt say blue its just when you move the adjustment bar up or down its mostly red or blue and inbetween is like green , what can i do?
    Problem Solver:
  • 8 Answers
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Posted on Dec 31, 2007
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
The tv is mostly red
replace the CRT coolant, as the green and blue get congealed and that causes the red to become dominate. You can get the Phillips CRT coolant kit at the following link which contains the coolant and the instructions on CD.
Jul 18, 2009 | Philips 50P8341 50" Rear Projection...
To much Red coloring and will not adjust
you may have bad cooling fluid you can tell by looking down in the tubes while set is on. they will appear cloudy
Mar 04, 2008 | Philips 55PP9401 55" Rear Projection...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
302 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
