Question about Dryers
We purchased part 280114 (rear drum seal) and we
We purchased W hirlpool part 280114 (rear drum seal) and we aren't sure which side to glue to the drum. Should we glue the surface that contains the strip of non-felt material?
    President:
  • 1,136 Answers
Hi, If this a whirlpool make, The felt side gets the glue. The edge that is sown tight on the edge gets glued to the tub. Make sure that you do not push the seal to far unto the drum so the flap on the seal hangs against the edge of the drum.
I tried looking up your part # and it doesn't come up.We purchased part 280114 (rear drum seal) and we - 5eff87c.jpg
If you look at the back side of this seal you will notice a threading closer to one side and not the other. The thread (felt side) closest to the edge is the one that gets glued to the drum.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 17, 2009
Open front panel on kenmore 77902791 dryer
Hello Barry Bosik,
Depending on the controls location...
(I think yours is REAR... you have a PARTIAL Number)
Most DRYERS open pretty much the same...
Put masking tape on a putty knife...
(to protect you finish) and push the release spring...
>> About 1 1/2" (inches) from the corner at front
straight back ( do not PRY )... Lift the corner & repeat
the push & lift on the other corner.
ELSE
just watch the VIDEOs
... These folks like to remove the top
(I don't... if it is a belt or fan... I will go the EXTRA MILE
to rig rope or cord to hold the lid...
>> Tape the DOOR SHUT.
>> A couple more screws loosens top front leans out
Here you might want to snap a picture
of how the front BOTTOM keys together...
You must make sure
it is properly fitted during reassembly...!!
Rather than point you to my favorite sire
(I will include below)... I am going to direct
your to SEARS... searspartsdirect.com
(a bit on the $$$$ side).
Water Filters Lawn Garden Appliance Parts
Parts houses (SEARS included) now have VIDEO
help... Unlike the "STUFF" on the general internet
These REPAIR videos are a good and decent
representation of the work required...
appliancepartspros
http://www.appliancepartspros.com/whirlpool-drum-felt-seal-280114-ap3790434.html#autoplay
repairclinic
Kenmore Dryer Model 110 77902791 11077902791 110 77902791 Parts
3 videos
Kenmore Dryer Blower Wheel WP697772
partselect
Whirlpool 661570V Drive Belt PartSelect
Jun 08, 2017 | Kenmore Dryers
How do I replace the felt seal
Most felt seals are glued in with a hi temp glue. Without seeing it I can't be sure but I think the drum has to come out to fix it properly. The glue can be purchased from most parts suppliers and sometimes comes with the new seal.
Mar 30, 2015 | Kenmore 700 6972 Electric Dryer
I have to replace the seal and drum supports. I have the dyer apart but the old seal was not in place. I have purchased the replacemant parts kit. It came with a foam strip, seal and lube. It looks to me...
What brand do you have?
the lube isn;t lube i think, yet a glue used to glue the seal to the drum a bead of glue downs on the lip of the drum and the seal around it. As far as the foam if i new the brand and model# i would know what that kit had in it and where it goes.
Aug 04, 2011 | Dryers
Hi, I ave a dryer purchased in 2004 model DBXR463ED1WW. The dryer has started to make the loudest squeaking noise recently and the operating instructions don't tell you now to remove the top or...
Hi totalgo...
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil or a light lubricant like Vasoline.
Reassemble the dryer, plug back in.
This should solve your noise problem.
This is a FREE answer, Please rate me
May 08, 2011 | GE DBXR463EDWW Electric Dryer
Need to replace rear felt seal what to do any glue needed
The felt seal replacement kit should come with some high temp. epoxy to glue the seal back on. The epoxy is quick drying and can be very messy. The easiest method to install the seal is to remove the drum from the cabinet and place it on its end with the felt seal UP. Remove the old seal and clean the old surface. Apply a thin film of epoxy all the way around the perimeter of drum and spread using an old paint brush or cotton swab (something you will want to throw away when done. Only apply enough to the surface area where to seal is applied. While the glue is still tacky, begin applying the seal to the drum, slowly working your way all the way around the drum. The glue is fast drying, so you will only have a few minutes before it begins to harden. Once the seal is in place, allow the glue to set up for a few minutes and reinstall drum.
The instructions come with the repair kit. If you post back with your MODEL NUMBER, I see if I can provide you with a part number.
Aug 24, 2010 | Dryers
Dryer 65291, burn marks
The problem you describe is usually caused by a rear drum seal worn and pinching articles during part of the drum's rotation. Replacing the rear drum seal is covered in great detail at the link below. Be sure to follow all links in blue that pertain to your machine. Caution: The glue that comes with the seal is VERY sticky and messy and comes out faster than you'd like at times. Do not get it on areas and items you're not prepared to discard. It is VERY difficult to remove once dry and it dries very quickly.
Rear drum Seal replacement procedure
Oct 02, 2009 | Kenmore Dryers
How to replace door seal on fs1455w
i use a glue called ec 847 or you could try gasket glue and duct tape(put door on top of dryer flat)don't slop glue all over hi hi
Aug 26, 2009 | Washing Machines
White clothes come out of dryer with brown lines.
Run a rag along the inside drum seals to see if this is the source of the brown lines. Replace the front and rear drum seals. Part number is 280114.
Mar 06, 2009 | Kenmore 63942 Dryer
Zanussi ZJ1217 loud rumble on spin
hiya m8 u need to take the lid off undue the first 2bolts on each side undue the bolts at the back and finally pull the plugs out off each side base and there will be a bolt undnerneath the plug now the complete back will come away letting u into the washer inners now u will have to undue the door seal from the front panel.Now there is a spring on each side at the top where u took the bolts from when u took the top off u will need a flat screw-driver to pop these out undue the electrical plugs from the motor,pump and anything else because u need to lift the drum completely out now undue all the bolts that go around the drum releasing both sides of the drum.Pull them apart now u need to undue the big bolt that holds the spider wheel on the back side of the drum place both hands on either side of this wheel and pull side to side until it pops off now u can pull the inner metal drum out u might need to hammer it a little with a rubber mallet once uve pulled it out u can get to the bearings one is behind a rubber seal these will need to be chiseled out this will be a hard job but sometimes u get lucky and they come out easy now to re-place them u will need some debor glue witch u can get from ebay and some metal red glue cant remember what its called at this time but u will get were u get the debor glue from put the metal glue around the outside of the bearings and make sure u do not get it on the inner bearing this will mess the bearings up now once the bearing kit is in u will need to put the debor glue all around the black rubber seal on both sides off this seal and place the inner drum back in tighten the spider back up and put both sides off the outer drum together again now tighten the bolts up again which go all the way around to fix outer drum together but 1st bolt should be then followed by the opposite bolt dont do the bolts up right next to each other because this will worp the drum slightly and it will leak now just put it all back together dont use for at least 3hours let all the glue that u have used go off this will stop it leaking at all this should take u at most 3hours to do an engineer will do it in half-hour this is the longest advice ive given ever so hope it goes well and happy fixing m8 let me know how u go on print this of it will be easier to follow next to u m8 peter
Jun 08, 2008 | Zanussi ZJ1217 Front Load Washer
Dryers Logo
308 people viewed this question
Top Dryers Experts
