Question about Yard Machines Garden
The machine runs from high to low and then shuts off what do I do?
  • 76 Answers
Hi
It sounds like you need to clean the cab .
I would recommend to take it for a professional service .
Posted on Jul 17, 2009
Condencer runs for 20 sec then off keeps repeting after 2 or 3 min goodman central system
Seems like it trying to start and then cuts out , possibly on overload. Try the machine on fan blow only , that will check the indoor unit to see if that is working. Then try cool or heat function while listening to the machine starting. If you hear a loud humming just as the fan starts, and then it cuts out, It could be a compressor issue. Possibly the start capacitor has failed.
May 27, 2015 | Goodman Heating & Cooling
My generator just stopped working!! What most likely would it be??
1-high temp shut-down
2-low oil pressure shut-down
3-low coolant level shut-down
4-high current/over-voltage shut-down
Mar 10, 2014 | Electrical Supplies
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Head light problems sometimes they will not shut off sometimes they (low beams) come on by themself high beam will not shut off
Are you sure there not running in daytime running light, when you think high beams are on
Also, there is sensor on the dash, usally on the speaker grate, that senses night and day. In the daytime your headlights will automatically come on when your car is in drive, and be on the high beam bulb, but dimmer than regular. At night, or in low light conditions, your lights will automatically switch from daytime lights to regular low beams. And yes, even when your switch on the dashis turned off, your lights work automatically.
To turn of the auto setting, just push the override button for your dome light, in and out 3 times, you should hear a chime, and your lights should shut off. This setting resets everytime you shut your vehicle off. Or to turn the auto setting back on, push the over ride button 3 more times.
Apr 15, 2011 | 2002 Chevrolet TrailBlazer
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Sep 12, 2010 | E-Machines eMachines Desktop PC
The air conditioner for my 2001 volvo v70 turbo will shut down periodically while running in hot weather or when running while the vehicle is stopped (traffic) for an extended period. Shutting the AC off,...
There may be a restriction in the plumbing of the air conditioning system that is making the high side pressure too high, thus shutting off the a/c for safety reasons.
Or, the refrigerant pressure on the low side is too low, caused by not enough r134a refrigerant in the system.
Aug 13, 2010 | 2001 Volvo V70
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
Ac comes on compressor runs maybe 3 minutes than shuts off and comes on again. Does this indicate a bad compresssor?
This could be do to low on refrigerant, a dirty evaporator or filter, or a blower not running or not running at the proper speed and a low pressure switch opening due to low pressure. It also could be due to a dirty condenser or condenser fan not running or not running at the proper speed and a high pressure switch opening and shutting the compressor off. It also could be due to maybe a weak capacitor or compressor drawing high amps and the internal overload in the compressor opening and shutting the compressor off, but if that's the problem it will usually take a long time for it to restart, maybe 30 minutes to an hour or more, depending on the outdoor temperature. This really sounds like a high or low pressure issue, but needs to be checked out by a service technician.
Jun 07, 2010 | Maytag M6X06F2A Air Conditioner
Engine revs high then low then stops
check the governor lever. it prob sticking or gone.
Aug 04, 2009 | Toro Lawn Mower With Toro Power Tools
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Garden Logo
32 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
