Question about Microsoft Xbox 360 Controller
Buttons A and B interfering with each other
My xbox 360 controller has a weird and annoying problem: pressing 'A' also presses 'B' at the same time! the same goes for pressing 'B'( it also presses 'A' at the same time) the two buttons are acting as one. This makes it impossible to play most of my games. I know it is not my Fault ( don't go asking if i'm not accidentaly putting my thumb on both, I am careful about what I press.)
    Scholar:
  • 44 Answers
They are "shorted" internally, either physically or electronically (through, for instance, static electricity). If the unit ever got wet, it is probably the first.
Since it's pretty useless as it is, you might want to open it up and take a look. (I've opened and even modified many of these.) I think there is one screw that is under the label, so this violated warranties, etc., but if it is covered by warranty, I'd get it fixed that way. I think there are four other small screws.
When you open it, some buttons will be loose. No big problem, but remember where they go. Then look at the electrical contacts where the A and B button touch. Is there grime or dirt? Perhaps a film left by a water accident? If so, you can get a Q-tip dipped in isopropyl alcohol (inexpensive at any drugstore) and rub moderately hard to clean it. Then let it dry and see if it helped. If you have a multimeter you can also check to see whether the A contacts or shorted to the B contacts. One from each will be shorted together. That's because they share a common connection with all the other buttons. But if the other pair is shorted too, that is your problem and you have the first sort of problem and it can probably be repaired by spotting the short and cleaning it as I described.
Posted on Jul 25, 2009
My xbox turns but the image docent pop out
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
May 21, 2011 | Microsoft Xbox 360 Console
All 4 lights keep on blinking on my controller
You may need to "Sync" the controller to your Xbox console.
1) Press the sync button on your Xbox 360. The green lights on the Xbox will swirl.
2) Press the small white button on the controller (between the bumper buttons).
After a few seconds, the position 1 green LED should light up on the controller.
Apr 05, 2011 | Microsoft Xbox 360 Controller
I can't get my remotes to sync with the console.
Connecting a controller to the Xbox 360 is one of those things that should be simple but always ends up confusing and difficult.
Wired is simple; just plug in the controller into a USB slot on the console. It should connect automatically.
For a wireless controller you do the following:
1. Turn on the Xbox 360.
2. Press center Xbox button on 360 controller.
3. Press the small "sync" button on the console.
4. Press the small "sync" button on the controller quickly after step 3.
Of course I never remember the order, so randomly mashing the Xbox button and sync buttons eventually works too. Here's a link to how to sync, but with pictures!
If you're using the Xbox 360 Universal Media remote, I believe it uses an IR (infrared) connection so there is no syncing involved. To use it you just need to point it at the Xbox 360 console (specifically, it's IR receiver). Just make sure the batteries in the remote aren't dead and that the remote is in 360 mode (as opposed to TV mode; just press the "TV" button to toggle modes).
Mar 22, 2011 | Microsoft Xbox 360 Console
No video have sound when using component connection on my xbox 360 hdmi ok. help
Your resolution settings on the xbox are too high for your currently used cables or tv. To reset your console's resolution follow these steps: To reset Xbox 360 console display settings
  3. Turn on the console by using your controller (its best to have the controller plugged into the console rather than just using the wireless). To do this, press and hold the controller's Xbox Guide button until your console turns on.
Mar 12, 2011 | Microsoft Xbox 360 Console
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
Feb 28, 2011 | Microsoft Xbox 360 Controller
My Xbox 360 Wireless controller keeps disconnecting in the middle of Halo: Reach matches. I have tried different batteries, different battery packs, and even different controllers! But the problem...
You should get a refund for the game or exchange it. Also you should go to Game Stop and see if they could fix it. There must be a bug in the game.
Sep 28, 2010 | Microsoft Xbox 360 Controller
I have just purchased another wireless controller for the xbox 360 and do not know how to connect it.
sync the controller to the xbox :-)
press the little button on the controller (near the LT LB buttons) and with-in 2 seconds press the sync button on the front of the xbox !
pressing These will make the green lights on the controller & the xbox rotate until eventually just the first player L.E.D stays on indicating player one :-)
play & enjoy :-)
hope this helps ??
Feb 17, 2010 | Microsoft Xbox 360 Controller
Main console does not seem to pick up controlers
there is a small button on the back of the controller...... press it......there is also a small button about "O" size on the front of the xbox 360......press that one as well.....after both buttons are pressed, the controller and xbox 360 will sync.
Jan 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 turns on by itself
Your controller has the ability to turn on the Xbox by pressing and holding the guide button. Check to make sure it is not stuck on any of your controllers. The Xbox can also pick up regular remote signals. One of your other remotes (if you have any) may be interfering with it. If your Xbox came with a media remote, make sure none of its buttons are stuck. Also, fluorescent lights (the swirly bulbs and the long, narrow bulbs) can sometimes trigger things. Another thing could be a Wii remote (if you own a Wii). There could be the rare possibility that it or the light bar is causing this problem. Sorry for the long message. I hope this helps!
Oct 18, 2009 | Microsoft Xbox 360 Console
Controller
you have to press the connection buttons, one on the controller and one on the xbox 360, the one on the controller is located on top by the triggers next to the cartridge insert port right by the left button, it has 3 wavy lines next to it, when you press it, the controller will light up and go in circles. After that quickly press the button on the xbox 360 located under memory unit A, to the left of the disc eject, then the xbox 360 lights will go in a circle then automatically connect. If it doesnt work at first, try it again, but quicker.
Nov 28, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Controller Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
