Question about HP LaserJet 3050 All-In-One Printer
Grinding noise and red flects of plastic or rubber coming out of the machine--paper crumbles and jambs as is copying or printing a fax
  • HP Master
  • 1,684 Answers
Your fuser assembly needs to be replaced. The material coming out is parts of a roller in the fuser that has been damaged. Check with your local repair shop, they should be able to get you back going.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
HP LaserJet 3050 All-In-One Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
