Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do you set/change the outgoing phone number on an HP Officejet 6110?
    Sergeant:
  • 168 Answers
Hit setup. Arrow to fax setup (4). Hit ok.
Arrow to fax header, hit ok. Enter name, ok. THAT should bring you to the phone number.
Posted on Jul 17, 2009
Can I change the amount of rings before the fax picks up?
Yes you can. You can press the Menu button and advance to Fax Set up or Advance Fax Set up and you will find the option in there. You can also google hp Officejet 6110 all-in-one Manual and it will take you to a site where you can download your own copy for this little wonder. Good luck.
Jan 04, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to open the hp 6110 to change ink
I will provide you with the Manual on your HP Printer below. Just go to the following Link below!
HP OfficeJet 6110 Owners Guide
Thank you for using Fix Ya!
Have a Great One!
Hope this Helps you out!
Feb 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 won't receive faxon single line phone with dsl
Have you tried to use the machine on a normal phone line? A dsl line shouldn't be any different as far as fax machines are concerned.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Outgoing fax
Plug the phone cord from the wall into the port marke "line" and not "phone".
Jan 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cannot receive fax but everything else works
Is the fax receiving setting set to "auto" or "manual" receive?
Jul 07, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
222 people viewed this question
Seeker5211
Seeker5211
