Question about Canon imageCLASS® MF4150 All-In-One Laser Printer
Canon mf4150 -- fax has a mind of its own?
My Canon mf4150 has done the strangest thing, ever since I first plugged it in (although it took a while for me to realize it was doing it). I have my phone hooked into the back of the printer, as it's the only way to use my phone and fax from on the same line. But every so often, seemingly randomly (although it seemed to really like to do this when I dialed into my voicemail), the fax would override the phone function, pick up, and try to send/receive information. How do I stop this, or is it something that requires me to send it back to Canon to fix?
  • lbgpress Jul 17, 2009
    That would be a great solution, except that my receive mode is on manual--i.e. it's never supposed to pick up as a fax unless I tell it to. Not only that, but it will pick up when I'm 30 minutes into a phone call... Plus, because the person on the other end hears that horrible "fax" noise, I'm guessing that the fax is trying to *send* something rather than receive. (Just a guess, though...) And even stranger, since I also rarely use it to send faxes, I can't imagine that there's anything stored that it thinks it needs to send.
Go into Additional Functions ->
select <5 FAX SETTINGS> -> press OK
select <3 RX SETTINGS> -> press OK
select <5 REMOTE RX> -> select OFF
If you turn it back on, you can set the 2 digit code to begin fax reception while you are not physically present at the machine. The default setting was '25'
Posted on Aug 27, 2009
  • 92 Answers
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <Canon mf4150 -- fax has a mind of its own? - la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
    Use <la.gif> or <ra.gifCanon mf4150 -- fax has a mind of its own? - la.gifs=> to select [3 RX SETTINGS]Canon mf4150 -- fax has a mind of its own? - ra.gif press <OK>.
  3. Use <la.gCanon mf4150 -- fax has a mind of its own? - la.gifass=> or <ra.gif> to select [3 RX MODE], then press <OK>.
    Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  4. Press <Stop/Reset> to return to the standby display.
Posted on Jul 17, 2009
How can I install my printer (Canon imageclass mf4150) without the cd and no needing fax capability? I tried installing manually but won't work any advice?
You can download the drivers for Canon MF4150 from Official Canon Site. Click here and go to 'Drivers & Downloads' - Select the Operating System you have on your PC (e.g. Windows XP) and you will get the drivers and software for you printer.
GoodLuck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
Dec 10, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Configure dates and telephone connection to enable fax
Copy this site to your web browser for the manual. Look at the Guides and Manual section for downloading the Instruction Manual for your Canon MF4150 Laser Printer. Hope it helps. (http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=14444)
Jun 03, 2009 | Canon MF4150 Laser Printer
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Fax recipt problems for Canon MF4150
My faxing not gothrough,what shold I do now?
Mf4150
Aug 29, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4150 Fax Problem
on the settings, it needs to be set for a certain number of rings, and also on auto receive
Jun 14, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
How Do i get a confirmation report after sending a fax
go to:
Additional functions
9 report settings
1 Settings
1 TX report
Output Yes
Jan 13, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
My fax keeps saying no anwser how do i fix this i need HELP!!
call the number you are faxing from a regular phone. If you get fax tones you need to check you fax line. Plug a non-digital phone into the fax line and place a call. Try that and let me know the results
Dec 13, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One Laser Printer Logo
621 people viewed this question
old marine
old marine
