i've had this rockford fosgate amp p5002 hooked up about two weeks and it would work for about 5 minutes then cut off and go into thermal mode. then the other day i turned on my car and there was no beat. found out the fuses on the back of the amp blew. now i tried hooking up a bigger ground wire, which i thought would help, and both fuses on the back of the amp blew again within like 2 minutes. what's happening here?
Comments:
Jul 18, 2009
- haven't tried that but i've noticed that the more i turn up the bass the quicker it overheats, so i'm thinking that has something to do with it.
first, check all electric your car audio system... may be it has a short connection. If that's ok... You must check the power amp wiring.... follow the manual... Then Check the impedance load between the amp and speaker or subs.... If this not help... you must consult the profesional car audio installer....
The premium audio system in my 06 Toyota Solara skips audio in the 6 cd, radio and tape player. All...
(More)
The premium audio system in my 06 Toyota Solara skips audio in the 6 cd, radio and tape player. All 3 have the problem!. It's a JBL system. It will work okay for awhile and then I will lose sound for a second or two and then it resumes playing. I need help!!!
the yellow wire on my sony is melting and blows fuses. if I let it cool down it works fine then...
(More)
the yellow wire on my sony is melting and blows fuses. if I let it cool down it works fine then after awhile starts getting hot and melting the wire again then the new fuse blows
i have a p5002 with an 8ohm jl audio sub .is there a way to make it louder even if its already...
(More)
i have a p5002 with an 8ohm jl audio sub .is there a way to make it louder even if its already bridged?
I just got a fosgate p5002. I am switching from a sony xm-2165gtx, it has a high level input...
(More)
I just got a fosgate p5002. I am switching from a sony xm-2165gtx, it has a high level input feed. What do I do with those wires. So far I have no sound from the fosgate. I have the inputs connected and the pos, ground and rem connected but no sound. any suggestions
