Question about Panasonic Lumix DMC-TZ1 Digital Camera
I AM GETTING MULTIPLE PICTURES WHEN I DEPRESS THE BUTTON TO TAKE PICTURES. IS THERE A SETTING I HAVE UNKNOWINGLY SET IN MOTION?
  • 1,511 Answers
Yes may be,
Check the settings for "Burst Mode" in your Cam, it will be under main settings menu. Turn it off, if the problem prevails better backup all the pics/videos and then Reset the Camera.
If helpfull, kindly do Rank.
Regards,
Waqar.
Posted on Jul 17, 2009
Alarm clocks
Depress and Hold the TIME button. Depress the HOUR button to multiple times until you get the correct hour showing. Pay attention to the AM/PM indicator to make sure. Then Depress the MINUTE button multiple times until you get the correct minute showing. Release your hold on the TIME button.
Jan 25, 2014 | GE 7-4894 Clock Radio
How to set self timer for D90
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
May 10, 2013 | Nikon D90 Digital Camera with 18-105mm...
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
How to take close-up pictures ?
Look for a button or setting that looks like a small flower. If there is one on your camera it will set up for close ups to about 7 inches. When done press the button again to clear the setting. The button may cycle through several different settings so you may have to press it multiple times to access the close-up mide.
Aug 13, 2009 | Cameras
Multiple copies of pictures
Yes may be, there was a same query here;
Regards,
Waqar
Jul 17, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Change military time to standard time on a Casio e-data watch
Depress the recessed 'Adjust' button (top left side) which will get the time setting flashing. Then depress the button on the lower right side once to get to the 24 hour time option. You will then have manually enter the time in that format. Once set, then depress the rescessed 'Adjust' button again.
May 21, 2009 | Casio E-DataBank DBC3101 Wrist Watch
Clock set on a 1989 Dodge Ram
with radio on depress the set button and "p" will be displayed within 5 sec. depress the sel button and hours and a flashing colon will be displayed, rotate the tuning knob clockwise to change depress sel button todisplay minutes, and make the setting the same way
Apr 18, 2009 | 1989 Dodge Ram D-Series Pickups
When taking photos at a basketball game and with my setting on the sports setting my pictures are coming out blurry and out of focus. How might I correct this?
Does the background look blurry? I suspect what you are getting is called motion blur. You need a faster shutter speed, which is either possible by having more light in the room or a faster lens.
If you want to try to get the best shot (with your existing equipment) possible of sports under low light conditions you may have to set some controls manually.
Use the Av mode, and set the Av number to the smallest one possible.
Adjust the ISO by pushing the ISO button on the back and setting it to the highest value (note: this results in a "noisy" picture, you will sacrifice color and see some specks in dark areas)
Set your frame advance to continuous by pressing the button on the left of the circle and setting it to the one that looks like multiple pictures.
And set your focus to "AI Servo" by pressing the "AF" button to the right of the circle and choosing "AF Servo".
Then shoot away.
Let me know how that works.
Mar 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camcorders
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Apr 24, 2008 | Video Cameras
Cannot get clear close-ups
Recommend not using flash. The first thing is that your subject should be well lit. Try placing it on a lighter background with good lighting around it. Also recommend using a tripod to keep the camera steady, and setting and using the camera's timer to take the photo (this also helps keep the camera steady). The closest auto-focused macro shot that the S200 takes is around 1 foot from the subject. Depress the shutter button halfway to verify that the subject is in focus (one of the three squares on the LCD should turn green on the subject). Next depress the shutter button all the way to take the photo.
Jan 24, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Panasonic Lumix DMC-TZ1 Digital Camera Logo
109 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
