Question about Canon MultiPASS MP730 All-In-One InkJet Printer
It just quit printing and copying
It just quit printing and copyin. It printed a file fine. when I tried to print the next one - I thought it was printing - but nothing just as if it was out of ink. Then I tried to copy a test sheet and the same thing. It accepts all the print commands wiyh no error messages BUT NO PRINT ON THE PAPER
  • 92 Answers
Hi ..
There could be multiple reasons for your printer not printing ..
1) Your printer is not setup as default.
2) Your printer drives need to be re-installed.
1) Your printer is not setup as default: If your printer is not your default printer, follow the instructions below to make it as default printer,
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' On the screen, right click your printer and then left click on "Set as default" option.
2) Your printer drives need to be re-installed: If you have the driver CD then use it to re-install the software.
Don't forget to vote if this helps ... Cheers :)
Posted on Jul 17, 2009
My printer does not print from the computer nor does it print copies.
Try this utility: Print Flush 1.3
Fix your printer with this small utility!
Has your printer quit working? Did you try to cancel a job and it broke the printer completely? I always do that. And the method to fix it usually involves rebooting, restarting the print spooler, trashing junk print files, and sometimes even more. Not anymore.
Print Flush has a simple function: clean the print spool. If your printer's driver is incorrectly installed, Print Flush cannot help you. If you have used your printer before and it worked fine then, but it doesn't now, Print Flush can probably help you.
It also works with Vista.
http://www.bradkovach.com/printflush/
  1. Save somewhere where you can find it.
  2. If you downloaded the zipped version... Unzip the file to the desktop or something
  3. Double-click the file
  4. Try printing again!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 20, 2011 | Dell 946 All-In-One InkJet Printer
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
I just bought this printer today and everything is hooked up fine, but it is not printing anything from microsoft word. It does copy and scan. What could be wrong and how should I fix it.
If it's only in Microsoft Word that it's not printing, then you should open up Word, go to File, select Print (the Print menu window or the Print Drop-down menu will open depending on your version) in there make sure there is NOT a "check" next to Print To File and make sure you have the printer you just bought as your Default printer (it should have a Black or Green check mark next to it's icon). Hope this helps!
Dec 14, 2010 | Computers & Internet
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
What is the best color copy with low cost per print
The best I've seen is Minolta magicolor series color laser printers, The next is the Samsung line of color laser MFP's, good color, long lasting consumables, fast prints.
Sep 15, 2009 | Xerox Phaser 6115MFP/D - Multifunction -...
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I WANT TO PRINT SCREEN
press the print screen button on your keyboard.
Feb 03, 2009 | E-Machines AAFQ50400000K0 Keyboard
Does not print letter from Outook Express
With the machine on. Press "Copy" and "Delete" at the same time and hold for 3 seconds. Then print "demo sheet". If the print and picture are OK try the next step.
Then try to print from a file in your computer.
If that doesn't work call Kodak Support at 1-800-421-6699. They are excellent.
Joe J
Aug 12, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
