Question about Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Describe your Kenmore 24032 24036 Top Load Washer Problem . Cold water is not runing through my washing maching.
    President:
  • 1,136 Answers
Hi, When the washer is set for cold water only, can you hear the inlet valve humming? Remove the fill hose from the inlet valve and look inside the valve to see if anything in plugging the screen. If the screen is open or the valve doesn't hum when there is power to it, the valve is most likely bad.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
No cold water filling into washer
The water inlet valve solenoid has probably gone bad. You can check it using a multimeter for continuity. These can go bad on just one side, so the solenoid is most likely faulty on the cold water side.
Sep 20, 2009 | Kenmore 22422 Top Load Washer
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
1.- replace timer
2.- or motor has thermal fuse check continuity.
3.- replace lid switch
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Kenmore 110.27822790 Top Load Washer
Check screens on the mix valve, hoses removed. If there is no humming sound when cold is selected then the mix valve needs to be replaced
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
