Question about HP Officejet 5610 All-In-One InkJet Printer
Printer ssays cartridge error and after we
Printer ssays cartridge error and after we changed the ink it says to look at documentation for trouble shooting. we lost the paperwork
I am having the same problem.Can't find the solution in the manual.
Posted on Jul 18, 2009
  • chloe250 Jul 18, 2009
    Found my solution. After trying everything, I just pulled out the color cartridge and printed with only the black one in. I didn't think it would work with only one cartridge in.I replaced the black ink today and it wasn't working until I took out the other cartridge.
    This problem happened before and all I did was to take out the cartridges, turn it off, put them back in and turn it back on but this time it wasn't that easy. Hope this helps.
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Hp officejet 4355 gives this message " cartrige error" refer to device documents for trouble shooting
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Mar 21, 2011 | Office Equipment & Supplies
I was printing a document when the printer stopped and this error popped up on the printers LCD (hp photosmart 2710) ''remove and check right ink cartridge'' how do I fix it?
1. your rt side ink cartridge is damaged change it with compatible or new cartridge to get rid from this error.
2. or try ones cleaning the cartridge with dry cloth.
Jun 10, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP photo printer D7360 error message
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
All The Best: Pineworks
Jun 04, 2009 | HP Photosmart D7360 All-In-One InkJet...
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
