Question about Zenith SY2551S TV
Connecting dvd player to zenith sy2551s system and doesn't work
I've connected my dvd player to my tv and it doesn't work. Is there a certain hook up for this type of tv or a certain channel it needs to be on to play the picture? Thanks.
  • 59 Answers
Re: Connecting dvd player to zenith sy2551s system and...
Yes, You need to be on AUX ,you can get to that setting by pressing channel 01 then press the channels down button instead of going to channel zero it will start to cycle through your AUX's inputs on the back of the tv.Also, another way to do this is on the original remote there will be a SOURCE button or INPUT button that can also cycle your TV through the aux inputs.REMEMBER.Make sure your DVD player is turned on and hooked up or else the AUX screen will be black.Rate me when you fix it!GOOD LUCK
Posted on Nov 18, 2007
0 characters
3 Points
How to get off blue screen
Check the TV by connecting it to an external antenna. If it works well with external antenna, check the input selection done after connecting the DVD player. Check whether Power to the DVD player is pluged in and it has been switched ON.
May 14, 2012 | RCA TruFlat 27F520T 27" TV
I cant find the av jacks to hook up my dvd player
This model doesn't have any A/V jacks. Many low-end RCA models didn't include any special features. They can only pick up signals over the antenna input. What you'll need to connect your DVD player is an RF converter, which takes the audio and video signals from the player and turns them into a channel 3 or 4 TV signal that the set can pick up.
RF converters aren't hard to find. Radio Shack, Sears and Wal-Mart all say they sell them, and you can certainly find them online. Hooking one up is just a matter of connecting the necessary cable to the player and TV, connecting the converter power and setting the output channel. Then put the TV on that channel and you're set. Unfortunately, this will give you lower picture and sound quality than you get from a TV that allows direct A/V inputs, but it's the only option.
Nov 21, 2010 | RCA F25422 25" TV
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Just trying to hook up a new DVD player to my 1998 Zenith TV?
Connect your video source [cable, satellite, etc] to your dvd and connect your dvd to your tv. Get back if you still have a problem.
Jun 19, 2009 | Zenith A25A23W 25" TV
Where do I get parts for this?
Try the two sellers below, if the part is not listed on the website, give them a call to order the part:
Encompass Parts Distribution
electronics parts & more from
May 22, 2009 | Zenith SY2551S TV
Cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Nov 18, 2008 | Zenith B27B40Z 27" TV
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Nov 12, 2008 | Zenith C27A24T 27" TV
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Sep 17, 2007 | Zenith Z25X22S 25" TV
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Standard (CRT) Televisions Logo
376 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
