SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
SOURCE: Whirlpool ghw9100l belt will not stay on drum drive pully
I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
SOURCE: Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
From
DIY washing machine repairs (2)
for repairs check
SOURCE: The belt from an Indesit washing machine broke a wire
The wire you refer to is an earth wire, it has probably pulled of the motor or the frame of the m/c.
If you can't see where it came from, don't worry too much, all you need to do is fasten it to a metal part of the m/c so that is is making a contact to earth.
I assume that you can get a belt o/k
Make sure that the drum and motor are free before you fit new belt.
Plz rate my solution
Thanks.
