SOURCE: ECM BATT fuse keeps blowing
That fuse provides power for the fuel pump. Either your fuel pump is blowing the fuse or there is a shorted wire.
SOURCE: the ECM fuse keeps blowing out
check the wiring to fuel tank something shorting. replace wires to fuel tank.
SOURCE: truck wont start keeps blowing the ecm batt fuse
You have a short (bear wire) somewhere. Trace the wire and find it.
Have a great evening
SOURCE: Fuel pump fuse keeps popping
You have a short to ground or the pump is starting to go bad. You can run a seperate wire from the hot side of the fuse to your pump to see if it is the pump or if you use an ohm meter to check the wire and the pump. Get's a little technical though.
