Question about Kodak Digital Science 3520DP Path-Through Scanner
Kodak 3520D scanner Front Scan Mod gain issue
I have a Kodak 3520D scanner that gives a black, blotchy image on half of the front image when scanning. Calibration gives an error saying "Front Scan Mod gain exceeds max: 0xbe, 0xc0" I have tested the scan module in another unit and it calibrates and works fine. What can I test next or what needs replacing?
  • carywoods Jul 21, 2009
    I have already checked lamps. I've replaced just about everything. I've narrowed the problem down to something on the main processing board. Unfortunately as this is a "scavenge to repair" job, I'm unable to proceed as I don't have any of those to replace it with.
  • Jarratt May 11, 2010
    are you sure you have checked the correct scan module in another scanner. The Front scan module is in the rear of the scanner.
    Problem Solver:
  • 7 Answers
Lamp need to be replace and re-calibrate.
Posted on Jul 20, 2009
  • n3bge Jul 21, 2009
    Have you replace lamp with a "new" one, not with another used one? and make sure that apature on the lamp face correct way.
    The error said that its not enough illumination.
I have 6 identical new PC's running Windows XP SP3 with Kodak i1210 scanners. 4 of them are running fine and scanning fine. The two giving me an issue are scanning fine as well but they are scanning...
Please check if the disk where you are saving has enough space. Defrag the drive for better results. If you are connecting the scanners trough an USB cable, try replacing them. Also check if the file format is same. If you have chosen to scan BMP or TIFF uncompressed or Color, the file size may be too big. I presume the other two PCs are free of virus.
S. Mohan
Aug 09, 2010 | Kodak i1210 Pass-Through Scanner
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
On a kodak 5100 printer how do I scan a document to the computer to use ss an attachment for E Mail?
Thank you for allowing me to assist you in this question. Below is some basic information on how to scan with this printer. The Kodak Home Center software will save the file into a directory into your computer and you can use your email program to attach that file into your emails.
To scan to a file
1 Set the Default scan destination to File with the Kodak Home Center software.
2 Place your original face down in the right front corner of the scanner glass.
3 Press Scan.
4 Press Start. The original is scanned and saved to a file on your computer according to the scan settings in the Kodak Home Center software.
To scan to an application
1 Set the Default scan destination to Application with the Kodak Home Center software.
3 Press Scan.
4 Press Start. The original is scanned into Kodak Home Center where you can open it with the application of your choice.
Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Scanned image appears to have an exposure problem
Are you using the software from HP? It sucks. Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away!!!!
Jan 10, 2009 | HP ScanJet 5300C Flatbed Scanner
Kodak i40 Front loading scan
Try downloading the latest Firmware for the Kodak i40 Scanner at the following Kodak.com page: http://graphics.kodak.com/docimaging/US/en/Products/Document_Scanners/Desktop/i40_Scanner/Support/Drivers_And_Downloads/i30_and_i40_Scanner_Firmware/index.htm
Follow the instructions carefully, and make sure that the scanner and the PC DO NOT turn off while doing the Firmware update. I recomend connecting both to a UPS with a known good battery while doing this upgrade.
This should install the latest features including the one that enables front feed.
Otaron
Jun 02, 2008 | Kodak i40 Path-Through Scanner
Kodak Digital Science 3520DP Path-Through Scanner Logo
483 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
