Question about Neff B1421 Electric Single Oven
Why doesnt the fan kick in on the higher setting?
Cooling fan on my neff oven stays on when I set it in auto is this normal
Are you sure you mean 'C ooling Fan' and not 'Circulating Fan' which should come on if the temperature selection is higher that the current temperature.
Oct 10, 2016 | Neff Ovens
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
Two fan speed. When do I use the high and low fan ie for what type of cooking?
the fan is just used as you please, if the food your cooking is more smokey , use a higher setting,, if the lower one keeps the air clear,, thats good enough,,
Aug 08, 2011 | Ovens
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
My hotpoint BD31 fan oven's temperature is about 30 degrees higher than the setting on the dial. What's the possible cause of this? Could it be that the fan mechanism isn't working?
If the fan was not working, then it would not get very hot at all as then fan forces the hot air around inside the oven.
Most manufactures allow a tolerance of plus or minus 10 degrees variation in temperature from the temp setting., so setting at 200 would give you 220 with 10 % plus, or 180 with 10 % minus, so yours is outside the acceptable range.
You can compensate by setting the thermostat 30 degees lower than normal, or the more expensive option, is to have a new thermostat fitted.
In my experience, compensating for the variation in temp, is a satisfactory solution.
However, if it gets worse, then your only course of action, is to replace the stat.
Trust this answers your question.
Nov 28, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven will not stay on .I believe it may be the timer
You have to ensure that the clock is set correctly with the time and it is in manual mode and nothing else is set on it.
Also that the background cooling fan has to be running as the oven overheat devices will kick in. This fan continues to run for about 10 mins, once the fan oven/top oven/grill is switched off. When it is running there should be a gentle draft of air coing out of the gap between the top and bottom oven doors.
Do you hear any relays operating when the fan oven turns off?
Sep 13, 2009 | Stoves 720EF Electric Double Oven
Neff B1421 Electric Single Oven Logo
57 people viewed this question
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
