Question about Refrigerators
Ge refrigerator side by side not defrosting; icing up;
Gsh22kgmb side by side not defrosting; icing up; have replaced heater twice and motherboard once
was there a recall on this? This refrig is less than 6 years old and has cost a fortune and no one can fix it
    President:
  • 1,136 Answers
Hhi, There has not been a recall but, they have changed the design of the heater. It is not a double heater. The new heater part # WR51X10101 . If you find the heater is bad, this is what you need to get. Since I have been replacing these new heaters, I have not had to go back and change another one. I hope GE got this figured out now.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Why is my side by side freezer not freezing
Most likely your refrigerators defrost heater is burned out. The PSS26MRSS has no defrost timer and defrost is done when the motherboard tells it to. I have not seen may problems with the mother board when it comes to defrost. Check the rear wall of freezer for frost and if yes unplug and remove contents and rear panel in freezer. Get a hair dryer to speed things up and once the ice is melted look for the defrost heater at base of the evaporator coil. When they burn out they are easy to spot because the outer tube is glass covering the defrost element inside. If burned out replace the defrost heater and defrost thermostat. I will instruct you, Thanks, Sea Breeze
Jan 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
When my refrigerator goes into defrost mode (twice a day?) it melts everything in the freezer. My ice bin is just one huge block of ice now. There is no ice on the back wall either. I replaced the defrost...
It sounds like a bad defrost timer. See if you can find another unit and see if it defrosts the same as yours or contact the manufacturer to find out.
Good Luck,
Gilshultz
Nov 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Our GE profile freezer/frig - frig side has ice on coils
Sounds like the automatic defrost system is not working. The usual problem is the defrost heater, the defrost thermostat, or the defrost timer. If any of these parts are bad, it will not defrost.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator and I just replaced the defrost heater last week because it would cool and than freeze up and I would have to turn in off and defrost it myself. Now it cools and stays...
Icemaker solid:
This could be a problem with the icemaker not dumping the ice or with the water valve in back not shuting off completely.
Water in the floor:
This may be related to the icemaker but first check the drain under the evaporator coils.
Dec 15, 2008 | Maytag MSD2656G Side by Side Refrigerator
GE sxs defrost problem
How long does it take for the frost to build up, improper placement of the bi-metal will cause a defrost issue by not letting the heater stay on long enough.
Let me know how you make out.
Thanks,
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
259 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
