Question about Samsung Televison & Video
Split picture on my Samsung LN32D450G1D, bottom half looks normal, top half changes colors pink and purple. This happens when it has been on for about 3 to 5 mins.
  • Samsung Master
  • 2,907 Answers
Forgotten the Password of the Lock Screen on Android,How to Unlock?
Broken data extraction tool does well in removing the password of PIN, patterns, password and fingerprint on Android. And this program covers over 6000 Android phones and tablets from Samsung, HTC, LG, Sony, Motorola, ZET, Huawei, Lenovo, etc.
Even the screen turns black, you are unable to open the USB debug, forget the lock screen password, Android touch screen cannot be used or just can't enter Android system for unknown reasons. There is still a chance for you to retrieve lost or deleted contacts, sms, pictures, videos, whatsapp chat messages, calendar on locked screen Android with this software.
LEARN MORE
Broken Android Data Extraction How to Restore Data from Samsung Phone with not Working Screen Recover data from Samsung galaxy S9 S8 When Forgotten the Password Pattern Recover SMS from Samsung Galaxy S6 with Black Screen
Posted on Oct 24, 2018
  • Samsung Master
  • 3,388 Answers
This sounds like an electronic temperature related failure.
Samsung voids the warranty if you attempt to repair it.
Best take it to the repair shop but if possible try warranty first.
Support LCD TV LN32D450G1D Samsung TVs LED LCD TV FIX How To For Samsung Double Image Black Vertical Lines Screen... How to Repair Samsung LCD TV http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=458&modelname=LN32D450G1D&modelcode=&session_id=&from_osc=
Posted on May 30, 2016
SOURCE:
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
  • 1153 Answers
SOURCE: Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Posted on Dec 27, 2007
  • 4 Answers
SOURCE: distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Posted on Aug 03, 2008
SAMUEL011
  • 39 Answers
SOURCE: There is green and pink on color on half of my lcd
I did some research and I found this link that will should you the schematic of the LCD technology,It sounds like one of you LCD color ships is not working properly,your TV has 3 ships (BLUE,GREEN,RED)
you can see how it work; http://www.oerlikon.com/ecomaXL/index.php?site=OPTICS_EN_lcd_projector .Whay happening is that due to the high density the lamp this ships tent to wear out and the three major color don't mix properly causing the color discoloration on your picture.You can find the parts you need at DM http://www.discount-merchant.com/?click=52978 (The correct diagnostic can only be made be a tech) I hope this info helps you please keep us posted .
Posted on Oct 07, 2009
  • 8457 Answers
SOURCE: Color is out of balance on bottom half of screen
This tv have covergence problems,it dead.The convergence board the 2 STK covergence ICS and some or all it resistors are dead.Must replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on May 23, 2010
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 28, 2016 | Samsung Televison & Video
32" Sanyo picture is half verticle lines various colors, half ok picture
Bad Tcon board or the cable going from the board to the panel, try that first by cleaning both ends if that doesn't help you need a new board
Jan 27, 2018 | Sanyo DP32746 32 in. LCD Television
My LCD television is showing pink and purple highlights whenever the color should be black
Normally when this happens the cause of the problem is either the lvds cable or the main board.
Sep 24, 2009 | Samsung LNT3242H Television
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Pixilated (purple) on top half of tv
Not your bulb, prob with the display unit. Could be a driver or decoder IC...accordianman
Sep 27, 2007 | Samsung DLP HL-P5663W 56" TV
Purple and white distorted fuzzy lines running up and down and side to side on tv
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Aug 19, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Open Questions:
Televison & Video Logo
161 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
