Question about Zeiss Classic B/GA 524013 Binocular
Left side is too loose how to tighten - Zeiss Classic B/GA 524013 Binocular
  • 3,230 Answers
from where it get loose.... tell me the exact position like from the front end lens or from the back end lens.... or from the mid side......
Thanks
Posted on Jul 17, 2009
How do I tighten the belt of a technogym excite 700 treadmill?
Easiest way is to remove the back guard at the back of the belt (dark grey). I think it's #3 allen keys. There are bolts on the side, and potentially underneath.
Once removed, you will see two large bolts that connect to the back roller. Turn those with a #8 allen key (I believe). If it is because the belt is loose, I'd only do 1/4 turn on each side at a time as you don't want to tighten too much or it stretches your belt, and may also cause your lower kit to blow something.
Jun 25, 2014 | True Technogym Excite Run 700 Treadmill
Hi, i have a proform 995 and the belt has shifted to the left side and is rubbing how do i center it?
hi you need to tighten the left side a turn or two and loosen the right side one or two. this is while the tread is on 3-4.once it moves over to where you want it. tighten the rite side . PS to tighten or loosen the bolts to the w/belt. clockwize is tight, and counter is loose
Mar 07, 2011 | Proform Power 995 Treadmill
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Bottom nut won't tighten and loosing fluid. Is there a tool to lock down dampener to tighten nut. Left side no problem not stripped either
I use an air impact gun to tighten. Also with the fork off, try compressing it some while tightening the bolt may help. Yes, they do make a tool, but I've done many forks without needing it.
Mar 19, 2010 | 1998 Honda XR 400R
How to tighten handlebars on a harley davidson 1997 road king?
If it is the clamp that is loose, remove the riser cover and tighen the 4 allem head screws. If it is the riser base that is loose, turn your bars to the left, look under the triple tree and you will see a large bolt head, one one each side, use a socket and tighten, swing the bars to the right, and repeat on the other side.
Happy riding!
Paul
Mar 12, 2010 | Harley Davidson FLHRC Road King Classic...
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
530 exc spacing between front fork & spacer
front axle installation: looking at the front of the bike:
slide the wheel into position and insert the axle from the left. with axle now through the right hand fork, install nut and tighten the left fork pinch bolts to secure the axle for tightening the nut. tighten the nut to 29.5 ftlbs. and loosen the left pinch bolts. now tighten the right pinch bolts and compress the front suspension while the left (from front) is still loose. now allow suspension to rest naturally and tighten all 4 pinch bolts to 11 ftlbs.
your done.......the axle is tighten against the rotor side and the other fork is then tighten in it's natural position so as not to cause premature seal and bushing failure and increasing stiction.
Sep 27, 2009 | 2008 KTM 530 EXC-R
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Lens is loose from body
One note on this fix. There are four screws that need to be tightened on the lens. With the cover off and the lens pointing straight forward, there are three small screws visible. After tightening them, rotate the lens upward to expose the fourth screww. After that one is tightened, you can then replace the cover and six cover screws.
Jan 18, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Zeiss Classic B/GA 524013 Binocular Logo
61 people viewed this question
Top Zeiss Optics Experts
Piyal Perera
Piyal Perera
Mark Campeau
Level 1 Expert
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
