Question about Shuttle MK32N Motherboard
Right light on MB next to mem slot - Shuttle MK32N Motherboard
  • 62 Answers
Hi and welcome to Fixya!
yes this is the light to show that the memory is inserted ...
Thanks for using FixYa!
Posted on Jul 18, 2009
I just completed a build of a new computer using an MSI H67MA-E45 rev B3 motherboard. Each time I reboot I hear 3 beep codes, 2 low-pitched and 1 high-pitched. Internet reading indicates a memory...
try them in the other slots if you can . and dose your board go that high with 8 gb.mem. check broad config for mem some will not take that.also see spec. of mem if not right will not work as well and can miss up display as well.jim
Jul 17, 2011 | MSI H67MA-E45 LGA 1155 Intel H67 HDMI SATA...
Cd تعريفات motherboard GIGABITE
you have gigbites right next to mem chips there in the slots right next to each other.
Feb 05, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
WE ARE GETTING "MEM TEST FAILURE REPLACE DIMM 1" M: 98240 19614
1. Turn the device off and disconnect the power cord.
2. Disconnect all interface cables.
3. Remove the right side panel by sliding it towards the rear of the device until the side slides from the device.
4. Open the access door by pulling on the metal tab.
5. Remove the DIMM from the antistatic package.
6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot.
(Check that the locks on each side of the DIMM slot are open.)
7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
NOTE To remove a DIMM, first release the locks.
8. Close the access door, and press firmly until it snaps into place.
9. To replace the right side panel, line up the alignment arrows and slide the panel toward the front of the device until it latches into place.
10. Reconnect the interface cable(s) and the power cord.
11. Turn the device on.
144-pin dual inline memory module (DIMM)
here's the memory part number/numbers you'll need also:
144-pin 133MHz DDR2 DIMM
Boosts the ability of the device to handle
large or complex print jobs.
32 MB CB420A
64 MB CB421A
128 MB CB422A
256 MB CB423A
Hope this helps and if so please mark fixya
Jun 25, 2010 | HP LaserJet P3005n Printer
Which slot to install mem upgrad 4g
If you're going to add a single 4gb stick,the next slot in line is fine, same if you replace all the modules,simply work from dimm 1 to 6(with an optional riser).If you're using quad link ram, then you skip a row between each slot unless you have atleast 4 sticks in a row of the same size. If not & you put them all in a row then front side bus drops to 800mhz & you lose the triple channel effect.
May 11, 2010 | Dell Precision T5500 Computer Workstation ...
I have 512 mb ram first it have 450mb useable bt nowadays only 300 mb only useable why ram memory is decrese & how would i do increase to 450mb
probably mem is being reserved for os or video card just put another mem stick in or if only have one memory slot get a 1gig stick
Dec 11, 2009 | Computers & Internet
Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Gateway GM5084 PC Desktop
IBM Think pad type 2366 - memory upgrade
Sounds like you have a T30 with the common memory slot problem. See the following for guidence.
http://www.thinkwiki.org/wiki/Problem_with_failing_memory_slot
Jan 29, 2009 | IBM ThinkPad T30 2366 Notebook
Mem card slot problem
you need a new memory card reader off of ebay or amazon. OR, the game is corrupt, and the mem. stick reader stops reading because there is nomore file to be read
Apr 26, 2008 | Sony PlayStation Portable (PSP) Console
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Thanks
Iqbal
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
Vga
I would try switching slots on the MB. I'd hate to think a new MB has bad slots, but I've seen it happen. You might also want to try the card in another computer that you know is working. If it works there, then you've got an MB problem, if it doesn't then I'd say the video is bad. Bea
Sep 11, 2007 | ASUS P4S8X Motherboard
Shuttle MK32N Motherboard Logo
81 people viewed this question
Top Shuttle Computers & Internet Experts
David
David
john smith
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
