Question about Friedrich WallMaster WS07A10D Air Conditioner
MODEL PH15K5SA-5 wHEN COMPRESSOR GETS HOT UNIT SHUTS OFF. wILL RESTART IN 10 MIN.
  • 30 Answers
You have a control that sencors Temp of the compressor - normally this happens when the winding in the compressor go bad, first clean unit completely then replace the bi Metal on the compressor - or replace the compressor if worth it ??.
Posted on Jul 18, 2009
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
Why is my air conditioner unit only running properly on cool days? when its hot out it only runs about 5 mins at a time then shuts off to fan and dont come back on for another 20 mins.
Do you hear a click sound as the compressor shuts down? If so that is the clixon (heat sensitive circuit breaker) that is opening and shutting down the compressor when it overheats. You have not had the AC filled with refrigerant so overfilling the unit cannot be an issue.
And if it is not overfilled overheating is caused by excessive current going into the motor which could indicate a problem with the motor windings..
OR, If the thermostat is faulty it could be prematurely shutting down the compressor. If you jump (bypass) the therm and unit does not shut off then you have found the culprit.
Sep 08, 2015 | Heating & Cooling
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Jun 02, 2011 | Dehumidifiers
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Friedrich WallMaster WS07A10D Air Conditioner Logo
111 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
