Question about GE (PSS26MSRSS) Side by Side Refrigerator
Instaled new water value no water toice maker or water
I can't get water to come to water despencer in door
  • GE Master
  • 1,606 Answers
Remove the bottom kickplate and find the hose coupling . Push in on 1 end and slide hose out . Then close the door and push for water . If water comes out the hose in steady spray , then your complaint would be door is frozen .
Posted on Jul 18, 2009
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Icemaker not working, the water despencer is ok, so i know there is water coming in ,it is in on position, no ice is stuck,what do i look for? next move
When the ice is frozen hard the ice maker has a heater that activates so the ice can be released, the a rotating mechanism rotates to push the ice out of the ice maker. Then cycle starts again by dispensing water in the tray. A lot of times the ice maker itself is defective and must be replaced. They are just attached by two screws and plugs into the freezer plug.
Feb 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plhs67es fridgidaire refrigerator no water despence or making ice
Always remember Safty First to turn off power and water supply and only turn them on as needed!!!
I checked water supply it was great and then check the valves (solinoids) and the power and all was good. The next thing I checked was the water from the supply valve to the filter at the same time I put some water in the ice maker to make sure it was working (leave it to make sure it drops the ice). The filter was new but was defective. Water went to the filter but did not return any to the despencer or the ice maker. During the different test I performed I also found that the lines hook to valves that the filter plugged into and since the new filter fixed the problem those valves were ok but could have been the problem therefore I suggest if you have this problem remove the filter and depress the small valve with a small object (like a hollowed out pen) and call for the water to be dispenced. If the water does not spray out then you have another problem...I went threw the whole system to find a bad filter, which I thought in the begining but since the other filter was new I done all of the above.
Although I figured out the problem myself this is a great Web Site. Thank You
Mar 22, 2009 | Whirlpool GS5SHAXN Side by Side...
No water toice maker
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water drips
try turning off water supply valve.if water stops, install new water control valve.
Sep 06, 2008 | Maytag MZD2766GES Side by Side...
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice maker quit
check water supply toice maker also check water inlet valve
Mar 05, 2008 | Refrigerators
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
185 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
