Question about Panasonic DMP-BD60K Blu-ray/DVD Player
Loud grinding noise in DVD player (blu-ray) when I play some dvd's. Sounds like the gears but not all dvd's do it!
SOURCE: Blu-Ray player not reading Blu-Ray movie
Go to sharps website and download updated firmware version for your model, then transfer the file to the blu ray using a usb mass storage device. I had to do that to mine it would not play new blu rays and i just bought the darn thing should've come updated. Good luck!
Posted on Dec 28, 2008
  • 10 Answers
SOURCE: dvd player reads "no disc" after inserting dvd
try getting new av./audio cords and use them it should work then if it doesn't then you need to return it. there is a warranty on most dvd/blu-ray players.
Posted on Apr 18, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
Posted on Jun 05, 2009
benwabnick
  • 2404 Answers
SOURCE: bu-ray will not read blu-ray dvd's
Reason it won't play blu-ray's now is because the laser is to weak. The laser requires a different strength to read the diffferent discs and if the laser is weak in any way then it will error out or freeze up. Either way you'll have to get a new player cause you cant get parts for it.
Posted on Jan 01, 2010
SOURCE: Universal Remote code for Insignia Blu-ray dvd player NS-2BRDVD
Insignia says it will not work with a universal remote there is no code.
Posted on Feb 02, 2010
RCA TV DVD Combo DVD makes loud grinding noise when playing DVD
does not sound correct. Perhaps the laser is hitting the DVD, or a gear is dirty. Anyway, if you keep playing with a strange noise in the player, it won't take long before it stops complete, or till you destroyed all your DVD's When you don't see scratches on the silver side of the DVD's, you should check (or let a technician check) what can be wrong with the player.
Sep 30, 2014 | Televison & Video
Loud hissing noise when I play a DVD
maybe the motor spindle are about to crash
Sep 19, 2012 | Philips DVP3150
The player makes a terrible noise when trying to play the disc. The disc wont load
I will strong recommend you to go to the repair shop TV for fix.
the reason is there many servomechanism inside that need LUBE , or replace gear broken or worn, or belt worn.and shaft needed lube and adjust it.
However see the flowchart.God bless you
7_21_2012_1_55_31_pm.gif7_21_2012_1_55_50_pm.jpg7_21_2012_1_56_03_pm.jpg7_21_2012_1_56_41_pm.jpg
Jul 20, 2012 | Televison & Video
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
My new C6900 Blu-Ray plays great, but when reading the DVD it makes a loud clunking noise. i have tried both regular DVD's and a Blu-Ray with the same results. I have a $39.00 DVD player that does not make...
Check the under side of the disc to make sure it is not scratched, if okay! what you are describing is a mechanical issue and should be checked out, because that is not normal and could indicate trouble ahead, this where your warranty comes in handy.
Jan 14, 2011 | Samsung BDC6900 3D Bluray Disc Player
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
Princess dvd player making grinding noise(Won't play the disk)
It is the problem of the cooling fan in your player .Provide lubrication
Dec 03, 2008 | Disney Princess MCP DVD2050P DVD Player
Panasonic DMP-BD60K Blu-ray/DVD Player Logo
783 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
