Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Where is the pump for the ice maker?
Our ice maker is not making ice...the water is not coming into the icemaker. either the pump is not working or the water pipe is stopped up.
    Champion:
  • 363 Answers
The solinoid valve for the water dispenser and ice maker are the same one, it is generally located at the bottom behind the unit.
Posted on Jul 19, 2009
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Kitchenaid Superba Ice Maker quit
    If you add some water there, yourself. It should make some ice for you, untill the water runs out.
    Try this
    http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
    Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker not working
    my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
    Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
    Ice machine isn't working
    Two things come to mind.
    First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
    The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
    Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
    the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
    Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    No water coming down tube in kenmore ice maker
    Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
    Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    Ice Maker not Getting Water
    There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
    Jul 15, 2008 | Kenmore 53642 / 53644 Side by Side...
    Ice maker not getting water in the line
    The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
    Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
    Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
    444 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
