Question about Sony PlayStation 2 (PS2) Console
Ps2 not working
After the kids ps2 stop reading disc my husband took it apart and dusted it out, then put it back together but now it does nothing!! It want even turn on. Help!!!
  • 709 Answers
He forgot to plug up the power cord inside.
Posted on Nov 20, 2007
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
I took my PS2 apart to clean the lense becaus it wasn't reading discs properly and when I put it back together I got nothing. No red light, no green light, no power whatsoever! Please help!
be sure that the wire that connects to the power buttons are property installed, also to the playstation, , be really careful.. also what you can do is just give them a small push to both of them to make sure they are getting a connection
Dec 22, 2010 | Sony PlayStation 2 (PS2) Console
The console works (comes on , tray opens and closes,) after putting disc in tray and closing it makes a sound like disc reading then stops ,nothing on screen ,,Is this a replace the laser job??
its not dealing with the laser. your cord inside connecting your ps2 top cover to your tray might be lose or not connecting like it should. take apart the ps2 and see if it is connected. if not place it back inside the tray slot inside of the ps2.
Dec 15, 2009 | Sony PlayStation 2 (PS2) Console
No disc works for PS2
Hi, it sounds like your laser is either dirty or dead. first try to clean your laser with a Q-tip and some glass cleaner (no streaks that way). This will require you opening up your PS2. Take all the screws out of the bottom os it and pull the top off, be careful there is a ribbon cable that is attached to your power and eject buttons. You will be able to see your DVD drive. take all 4 screws out and take the top off. The laser will be right there. Swab the laser with the Q-tip and use the dry end to dry it off. Put the top back on and plug it in to the wall and your t.v. See if it will read the discs before you put it back together. If it won't then your laser is shot and needs replaced. But while you have it apart you can order a new laser for about $29.00 and install it while its apart. If it does read the discs then its fixed and you can put it back together.
Aug 09, 2009 | Sony PlayStation 2 (PS2) Console
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
Bought playstation 2 guitar hero world tour , doesn't work
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Nov 17, 2008 | Sony PlayStation 2 (PS2) Console
Fix ps2 disc game and go faster to load.
its a ps2 problem open the ps2 up if its a big ps2 not a mini and dust it the dust is making it harder for your ps2 to read disks open it dust it and itll be like barnd new if its a small ps2 i dont know dusting the thing always help dust with somthing small a cotton ball or ear swab will work
Jan 01, 2008 | Sony PlayStation 2 (PS2) Console
PS2 "Slimline" Can not read disk?
the problem I had is my ps2 slimline wouldn't play ps2 games. so I went on line and followed instruction took it all apart cleaned everything nothing. put it back together, for some reason I openned the ps2 where the disk goes there you can see the eye, I took a small flat heat screw driver the ones you use to fix eye glasses, and put it under the eye assembly and so gentle pushed it up. now it works perfect. not to hard you don't want to break it, I didn't even see it move. Hope this helps
Dec 03, 2007 | Sony PlayStation 2 Slimline Console
it sounds like the disk isnt locating when it slides onto the laser tray if you are ok taking it apart check nothing is blocking the laser tray if their is nothing blocking it check that the laser has retuned back to the middle of the tray if it hasnt then gently push it back and then put it back together. if this dont work you might need to buy new laser witch you can get off ebay they are easy to fit the wires only go into a snap conector try this this should solve your problem
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
PS2 problem
It's likely the lazer lens is out of alignment or requires replacing. Did your dvd cleaner also have a lens aligning part to it, you normally go through a spoken instruction(go to track 2 etc), as cleaning is sometimes not the only required solution.
Jan 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
