Question about Carrier XHD183D Air Conditioner
How many btus is this unit - Carrier XHD183D Air Conditioner
XCB183D is 18,000 btu.
Posted on Jul 22, 2009
What size oil furnace is needed for 1200 square feet?
75000 to 85000 btu Or British thermal pound.
Two units of measure are important in sizing an oil furnace. The first is the British Thermal Unit or BTU, which represents the energy needed to raise the temperature of one pound of water by one degree Fahrenheit at normal atmospheric pressure. The input capacity of an oil furnace is often stated using this unit of measure. The second number is the fuel efficiency rating, which is expressed as a percentage. This represents the amount of energy that gets converted to heat, with higher numbers being better. To determine the energy output in BTUs per hour, multiply the input BTU by the efficiency rating. For example, a furnace with 100,000 BTU of input and an efficiency rating of 89 produces 89,000 BTUs of output. One with an efficiency rating of 80 and the same input amount, produces only 80,000 BTUs of output.
Read more: http://www.ehow.com/info_12197488_size-oil-furnace-required-1200-square-foot-house.html#ixzz2jfsuqLFx
Oct 25, 2013 | Heating & Cooling
Need tonnage for Carrier model# 48TCED08B2K5A S/N 2610G30670
You see that 48 at the begining, that is 48,000 btus. 12,000 btus per ton of cooling that makes that piece of equipment a 4 ton unit. hope this helps.
Oct 27, 2011 | Carrier 38CKC042 Air Conditioner
Morning, I got a external unit SH24BP2X samsung fro air conditionning, and I'ld like to buy an indoor unit. Is anybody can give me ref which match with this unit. I need 5/6 kw heating power. Thanks...
The 24 in your model number means 24,000 btus. There is 12 thousand btus in a ton of cooling. This makes your unit a two ton. You can buy a air handler sent up for two tons of cooling and then buy what every electric heat pack that you need. let me know. wally
Mar 16, 2011 | Samsung Heating & Cooling
Whats the tonage of this condenser
Tons of cooling or heating are done by btus.
So 6000 btus is 1/2 a ton,12000 btus is 1 ton.And so on.
You need to get the total btu rating off the unit then figure it out.
Dec 29, 2010 | Heating & Cooling
My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside...
It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Using the square footage and the chart below, determine the correct cooling capacity. Cooling capacity is measured in British thermal units (BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
100 up to 150 5,000
150 up to 250 6,000
250 up to 300 7,000
300 up to 350 8,000
350 up to 400 9,000
400 up to 450 10,000
450 up to 550 12,000
550 up to 700 14,000
700 up to 1,000 18,000
1,000 up to 1,200 21,000
1,200 up to 1,400 23,000
1,400 up to 1,500 24,000
1,500 up to 2,000 30,000
2,000 up to 2,500 34,000
Make any adjustments for the following circumstances:
If the room is heavily shaded, reduce capacity by 10 percent.
If the room is very sunny, increase capacity by 10 percent.
If more than two people regularly occupy the room, add 600 BTUs for each additional person.
If the unit is used in a kitchen, increase capacity by 4,000 BTUs.
Consider where you install the unit. If you are mounting an air conditioner near the corner of a room, look for a unit that can send the airflow in the right direction.
Jun 17, 2010 | Heating & Cooling
Trying to find ton rating for a Tempstar 9000 mod# CA903VKA2.
If this is a window or portable unit, you will not find the tonnage only the BTUS. My guess is 9,000 BTUS
3,000 less than a ton
Does my hampton bay unit blow heat
if it does, on the name plate it will have a split rating for the btus. one for cooling and one for heating. if there is only one rating i.e. 8000 btus, then it is just for cooling
Dec 11, 2009 | Heating & Cooling
I had two very different quotes for installation. They recommended different models and different blowers. 15k vs 17k mxz4a36na vs mxz3a30 model. By getting the less expensive model and smaller blower...
The last two numbers in the model number indicates the Btu ratings. The mxz4a36 indicates that this unit is capable of putting out 36,000 Btus and only 30,000 Btus on the other. I would be concerned that the second unit is large enough to satisfy your cooling load. Forget the power, make sure the unit is sized properly.
Nov 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Carrier XHD183D Air Conditioner Logo
66 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
