Question about Datamax DMX-I-4208 Label Printer
Datamax I-Class DMX-I-4208 takes long time to print
I have a Datamax I-4208. When I print, the printer does not react for a very long time... several minutes. If I go to the Print Queue, the status says "printing." If I "cancel" the job, the printer will print the info immediately, BUT in really tiny letters. This tells me that the communication is there, but why won't it print in the first place? Is there a setting on the printer itself that may not agree with the EasyLabel Platinum software?
SOURCE: Datamax DMX E4203 Printer Problem
that is the solution
Posted on May 15, 2008
  • 27 Answers
SOURCE: Present sensor faul on Datamax M class
Apparantly, you have the present sensor enabled in the printer and there is no physical present sensor option installed. Go to the printer menu by pressing MENU. Press FEED until you get PRINTER OPTIONS and then press CANCEL. Press FEED until you get to PRESENT SENSOR and then press CANCEL. Press FEED until it says DISABLED and press CANCEL. Press MENU repeatedly slowly until you get a prompt to save changes then press CANCEL. Press FEED to clear error and it should go away.
Dman
Posted on Dec 29, 2008
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
  • 54 Answers
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Posted on Feb 25, 2009
  • 67 Answers
SOURCE: datamax dmx-i-4208 (ribbon fault)
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
Posted on Nov 07, 2009
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
When we print labels, it skips one each time. We have been on the phone with Datamax three times and all systems appear normal. When we do a test of the Datamax it DOES NOT skip[ any labels but as soon...
Hello, Nancy.
It's clearly your application, since a test print appears normal and all systems appear normal. Is it possible to reinstall your application ?
Hope this helps.
Mar 06, 2011 | Datamax DMX-I-4208 Label Printer
How much does the I class actually weigh in Kg?
Hi Adam. Here is a link to the spec. sheet. http://shopper.cnet.com/label-printers/datamax-i-class-i/4014-3163_9-30719556.html#info-5
It weighs 45.2 pounds which is 20.5 KG. One Kg is 2.2 pounds. Joe
4 thumbs up please. ty
Nov 08, 2010 | Datamax DMX-I-4208 Label Printer
We have several Datamax I-4208 printers and a few of the older I-4206 models. It would appear the replacement printheads are one in the same for both models be we cannot get either of our spares to work in...
Some changes were made on the I Class units and the new printheads do not work correctly in the discontinued 4206 models. You need part number DPO20-2262-01 for your I-4206.
Jan 18, 2010 | Datamax DMX I-4206 Printer
Datamax DMX-I-4208 Label Printer Logo
198 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
