Question about HP LaserJet 1018 Printer
My computer can not see my printer which was working until wednesday
Doe your printer gets on then check the usb cable
Posted on Jul 25, 2009
If you still have the installation disk try reinstalling the printer. Don't forget to use a different name, like LJ1018_July.
If you have lost the installation disk, search the manufacturer's website to locate the appropriate driver.
The problem you have occurs sometimes when you have a print job that jammed and the software does not empty the job queue.
If the solution above does not work, try a new cable between the printer and the computer.
I cannot connect to my broadband
What's Wednesday got to do with anything? What did you do on Wednesday. Can you undo it?
Sep 05, 2014 | Televison & Video
Is the day of the week in the middle of dau or night or at the beginning it on the GE vacation timer?
Vacation timers turn lights on-and-off at random times.
Timer dial rotates clockwise. Notice small arrows on timer dial located below each day letter.
Each day starts at the letter.
When the time-now pointer is at W, then wednesday starts.
For example W is wednesday. And th is thursday. The hours that show between W and th are wednesday hours.
Open following image. The time now pointer is pointed at 4:00pm Wednesday.
The blue letters with white background are AM, and white letters with blue background are PM.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
To set current time, rotate dial clockwise until current time lines up with time-now pointer.
Time-now pointer is stationary.
Open following link to see how to set timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | GE 50462 7Day Random Vacation Timer
Check reception is scrolling on screen
I am constantly seeing this problem arriving on this website. This is not a problem. The radio is just letting you know that you haven't received any warnings or tests for a certain amount of time. All you have to do is watch your radio every Wednesday around 10:00 a.m. until you see the advisory light come on. Keep watching the radio throughout the day because the test can begin at anytime. The reason why I am stating "watch your radio every Wednesday around 10:00 a.m." is because this is when the NWS starts their Required Weekly Tests (RWTs) or Required Monthly Tests (RMTs). Depending on what kind of test your county runs will determine what Wednesday you get this test. If it is a monthly test, you will receive this on whatever Wednesday that your county is scheduled to give this test (i.e. the 4th Wednesday of the month). You wouldn't be getting this message if you were getting an RWT. The NWS radio station for my reception area gives the test on the 4th or last Wednesday of every month. The advisory light will stay on for a few hours, but it will eventually go off. Hope this solution helps. Reply back if it doesn't. The real solution to this and key ingredient is patience.
Jan 16, 2011 | Midland WR-100 Weather/RDS Radio
Printer not printing, only a page of a 2 page article.
you did not stated what computer and what operating system, telepathy do not work very well...
i assume that printer is connected via wireless? and you operate some flavour of windows?
if that is the case, please follow procedure below:
1. open notepad
2. type exactly lines below:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
3. save as on desktop: DeletePrintJobs.cmd (do not delete it after! you may need it in years to come!)
4. click on it with right mouse button and then left mouse button and run as an administrator, this commands will delete all spooling jobs for the printers, regardless of the brand.
5. reboot your computer
if this did not work, then follow procedure below, this is true towards usb as well as wireless:
1. switch off printer and disconnect power cord to it
2. remove all drivers for the printer
3. run procedure from above then after restart
4. use ccleaner and clean your computer as well as registry
5. re-install printer using newest drivers appriopriate for your operating system, be it 32bit or 64bit as this is most common cause of this printer mis-behaviour
6. re-connect the printer
re-examine your wireless settings and set it as follows:
1. download and update from router manufacturer your firmware for your router, model and version
2. set SSID broadcast, change if you want to
3. set security to "WPA Personal", "WPA-PSK (TKIP)
4. set password, it need to be at least 12 characters (mixed!) long, do not use dictionary or common words!
5. set mode to "b" and "g", or if available on all your devices "n"
6. set channel to 1 or 6 or 11, these are most clear channels for most devices
7. disable/skip MAC address filtering
8. keep DHCP settings
9. save all changes
10. reboot router after changes, it will take up to 2 min
11. switch off all systems
12. re-power everything after 20sec
13. re-establish all connections
this procedure should keep your wireless connection at optimum and life relatively easy.
if you find my advice useful, please do nto forget to vote for me
Jul 31, 2010 | Dell V313w AllInOne InkJet Printer
HOW DO I SET TODAY MONDAY, SO THE PUMP WILL START ON WEDNESDAY? I PUT MONDAY IN FRONT OF 14 ARROW AND PULL THE PIN OUT FOR WEDNESDAY BUT AS ALL PINS PASS ON YELLOW DIAL TO GET TO WEDNESDAY AND THE 12 MIN....
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/images/R8806P101C-timer-778.jpg
1) The silver pin goes at 12 midnight on large yellow dial. This pin advances the skipper wheel each day.
2) Turn yellow dial clockwise until current time lines up with silver pointer.
3) Rotate skipper wheel counter-clockwise until today's day (Monday) is in front of 14 arrow.
4) To skip a day of watering, the skipper pin is pushed down for that day. So you want to push down Monday and Tuesday.
For watering, the skipper pins is up for that day. So you want The skipper pin up for Tuesday.
5) The brass trippers are inserted on yellow wheel. Each brass tripper represents 12 minutes of watering for example. So if you want to water for 1/2 hour, then put two consecutive pins on the yellow timer wheel. For 1 hour, put 4 consecutive pins.
May 17, 2010 | Intermatic R8806P101C -...
Printer has stopped printing .pdf files
Check your list of printers and make sure the default printer is the correct one.
Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
Feb 25 - Canon Imageclass no longer prints after Microsoft update
yes your best way is to do that! i would go to canon.com and download the latest update just so thats not a factor! and the if that doesnt work just uninstall the latest update, which can be done from windows control panel!
driver should do it though!
Feb 27, 2009 | Canon ImageClass MF5770 Laser Copier...
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Seeker5211
Seeker5211
