Question about HP Compaq Presario v3000z Notebook
The mouse buttons on my touchpad do not function most of the time. Is this pratical to fix? How?
Touchpad, I want to disable the touchpad/mouse, temorarily. My pc repair man stated NO NOT install any program to do this. He went to the control panel, mouse, and found the icon, however, this would...
check on the F1 to F12 buttons one of them come with the laptop Mouse icon, in different color most times,
Use FN button (close to CTRL button) + the mouse button, it may disable it..
send me the brand and model of the laptop, I might help you better
Sep 07, 2013 | Lenovo b560 Notebook
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem my internal mouse is locked, I dont know why and dont know how to fix it (I dont use an external mouse or keyboard). ...
Hi melissamhahn..
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | HP Pavilion dv9000z Notebook
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
Sep 05, 2011 | Toshiba Computers & Internet
Vertically and horizontally finger scrolling on my vaio laptopnw series is not working any more or maybe i have deactivated it,i had a touch pad icon on my toolbar hiden icons before ,but not anymore.how...
Hi sheki_68,
If you have disabled the Scrolling Feature of the Touchpad, you will need to re-enable for the function to work correctly. You can enable the Touchpad Setting from the Control Panel, Mouse Options.
  1. Click the Start button and then click Control Panel .
  2. In the Control Panel window, click Hardware and Sound .
  3. In the Hardware and Sound window, click Mouse .
  4. In the Mouse Properties window, click the Function tab.
  5. To enable the Scroll function, click to check the box next to Use Scroll Function.
  6. Click the OK button and then close the Hardware and Sound window.
This should re-enable the Scrolling Feature of the Touchpad. If the Function is not available in the Mouse Properties window, you may need to re-install the Touchpad Driver in the Computer to fix it.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 20, 2010 | Sony VAIO NW270FS Series 155" Notebook PC
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad & lower 'mouse' buttons do not work
There is a button on the laptop which re-enables the touchpad. It's either next to the touchpad, or you must hold down the Fn button and press one of the function keys at the top.
Jul 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 08, 2009 | HP Pavilion dv9000z Notebook
Mouse cursor wont move
most laptops have a way to enable/disable the touchpad for those that use an external mouse or do alot of typing and encouter the overactive touchpad.
hold the "FN" key and press the corospinding function "f button" to enable it.
the function key number will be different depending on your laptop and you should also check the laptop base for a button that may be specifically for this purpose.
Good Luck and Happy Hunting!! :)
Mar 10, 2009 | LG X-Note LM50 Notebook
Frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Jan 25, 2008 | Toshiba Satellite M35X-S161 Notebook
HP Compaq Presario v3000z Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
