Question about LG 42PX5D 42 in. Plasma HDTV
Turn my LG 42PC3DC-UE 42in. and all it do is click on and off what can i do about that
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common problem are the power supply for the screen itself. Most manufactures call it a Blacklight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 18, 2009
Machine displays UE when spinning and turns off the machine, this occurs even when the machine is empty
UE means uneven for LG washing machine. Could you please using water level to make sure it is level. May I know if the drum is stable while spinning by not giving any banging sound. Used to happen to my LG direct drive, and solved by replacing the suspension that supporting the drum holder. Now all good like new.
Dec 24, 2013 | LG Washing Machines
I am getting alert of UE for fully automaticatic washing manchine
According to Lg Ue error code is an unbalanced load error code or uneven load error code you can also click this link from the LG site which describes some ways to alleviate the problem of the UE error code http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800. I have also found that if these ways do not remove the problem you may have to open the unit and check the damper struts that attach to the tub assembly. If one of these struts were not to be attached or have broken, or came away from the tub assembly this would also cause the UE error code as well with the unit. Also if you remove the rear panel you will see the stator which is basicly the motor as well as an rps sensor which helps the stator to rotate. I also have found that in some cases the center bolt that holds the stator in place sometimes unloosens and unscrews as well also causing this UE error code. So you would first try the methods that LG has listed in order to alleviate the UE error code and if there methods did not work then you would first look at the stator center screw to assure that it is tightened and in place. And secondly if the stator screw were in proper place and tight then you would look at the damper struts in the unit lastly. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Jul 04, 2011 | LG WM-2277HW Front Load Washer
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
May 20, 2010 | LG Washing Machines
LG 42PC3DV-UD turns off/on by itself. Is this a common problem? What part needs to be replaced?
Power board have dead capacitors,like puff up or burst open,these capacitors must replaced.Know how to solders?Or replaced the whole power refurbish power board.Tries Shopjimmy.com,Ebay.com.
Jan 19, 2010 | LG 42PC3DC 42 in. Plasma HDTV
Plasma TV turning on and off
Ur power board it dead,know how to solders?Recheck the power board for Capacitors puff up or burst open.Or buy a refurbish power supply board at Shopjimmy.com,Ebay.com for replacement.
Jan 16, 2010 | LG 42PC3DC 42 in. Plasma HDTV
61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Oct 12, 2009 | LG 60PC1D 60 in. Plasma Television
Tv Power
It sounds like the backlight fluorescent bulb is burned out.
Oct 26, 2008 | LG 42PC3DC 42 in. Plasma HDTV
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
487 people viewed this question
Computer Repairing
Computer Repairing
