Question about Freezers
During hot weather my traulsen URDT2-24DUT does not get cold enough to keep food its at 48 degrees. freezer side okay. I live in California and the technichian out here charge $150. just to show up with out repair any simple repair is about $1000.
  • 122 Answers
48 degrees is way too warm. When is the last time the condenser coil was cleaned? Its the fan coil on the exterior of the unit.
Posted on Sep 23, 2009
How much electricity do I need to keep my Woods chest freezer running during an extended power failure?
The amount of Energy is determined by the Efficiency of the Fridge, the Generator Output and the Size of the Fridge. Then you have to take into consideration the amount of food inside because it is what keeps the food cold. An Empty Fridge has nothing to retain the coldness
Oct 02, 2014 | Freezers
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
My service man replaced the defrost cycle timer and the relay (timer was definitely broken, relay was highly suspect) but the freezer fan still has no power so freezer will not chill adequately despite...
Most all commercial freezers have a fan delay/ defrost terminator. It is usually mounted on the end of the evap coil. It's purpose is to sense the temp of the coil during the defrost cycle. When it hits a preset temp., usually around 55 degrees or more (depends on Mfg.) It terminates the defrost cycle. It also doubles as a fan delay. It allows the evap coil to cool off from the defrost cycle before allowing the fan to come on. Usually, the coil has to get around 20 degrees before fan will energize. I would look for this as a possible problem. It could be one device with 3 wires or 2 separate devices with 2 wires each. I've seen it both ways.
Hope this helps.
Nov 19, 2009 | Traulsen 46 cu. ft. Commercial Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 | Freezers
Traulsen freezer urns for about 2 weeks then stops getting cold enough
Will it restart again? How old is this freezer? Could be start relay loose or a burned wire connection, worn out compressor. Let us Know what you find
Oct 12, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezers Logo
137 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
