Question about Tower Aloha Breeze Fan
Wanna know if i can make the air cooler . not sure what the opening in the top of the fan is for. am i supposed to put water in there or something? E
  • 308 Answers
You can not make the air coming out of a fan any cooler, as all a fan is doing is circulating air, (creating a breeze) which in turn makes you feel a little cooler. And no, do not pour water into your fan! Hope this helps
Posted on Jul 17, 2009
Can i run Lincoln 4.6 aviator without thermastat ?
You can run any car without the thermostat.. but the car is suppose to run with certain water temp. This is what the thermostat controlls. If you take it out check it by boiling water on your stove and If it does not open that is your problem.see if it open at 200* or less. use meat thermometer. If you take it out and the car still runs hot the problem is somewhere else. Like the electric fans are not running, The Water pump is going bad. loose fan belt not turning the pump, Something trash blocking air from radiator.. check all of these things. the car is running hotter something else is wrong. If you live in a really hot place you can buy a lower temp theromstat.. they come from 175*-210*. you really should run one.
May 12, 2014 | 2003 Lincoln Aviator
2007 isuzu npr overheating
First off , everyone needs to know that a 2007 Isuzu npr has a EGR cooler in which hot exhaust gas is cooled via coolant , if your not familiar with this system or truck than you should not be posting. Their is a TSB on this issue , you may have a hole in your EGR cooler and exhaust pressure is getting into coolant system. Do you have any black particles in your overflow bottle ? Remove your Egr cooler , plug one coolant port and put 30psi shop air in other port with a gauge attached , pressure drops and you have a hole . you can also keep it pressurized and submerge in water and look for bubbles . Bet you that's your issue , haven't had many of these head gaskets go bad.
Oct 15, 2012 | Cars & Trucks
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Exhaust switch
I think that just controls a little flapper that opens to the outside. I saw something like that on an a/c unit about 3 days ago. Lets fresh air in.
May 22, 2010 | Amana Cool Zone 29M43PC Air Conditioner
When I fire my computer up is says I have a CPU fan error and will not boot up. It is a Gateway Laptop. Is this something I can fix myself
Possibly. If you know how to open up computers, you can open it up (the screws are on the bottom) and check that the fan is connected to the motherboard and clear any dust out of there. If you don't feel comfortable, take it to a local repair shop. They will order you a new fan and replace it for much cheaper than a big company like bestbuy would.
Aug 21, 2009 | Computers & Internet
Water on the squiral cage side I don't know where its coming from
I don't know exactly what you mean by getting water on the dry side of the compartment. In any event, as you will see, there are very few sites that are dedicated to the maintenance and repair of evaporative coolers--you, in fact, submitted this problem of yours under the Air Conditioner section because there is no Evaporative Cooler section.
Having said this, I offer you two things: 1) a site that has a section dedicated to evaporative coolers, which took me a long time to find for my own problems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
and 2) the general idea that if you have water where it is not supposed to be, it likely is because there is a hole---obviously caused by rust--that allowed such water to get penetrated through. See more on rust holes of coolers here:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Has_Holes.htm
This should help get you on your way.
Brad
Jun 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Condensor?
It probably shut off on high pressure. Let it cool down, plug your hole that you drilled and give it another try. The water is suppose to collect there and the fan is suppose to throw it into the condenser to keep it cooler and make it run more efficiently. Good Luck,
kstfas
Oct 09, 2007 | Frigidaire FAH106N1 Wall/Window Air...
Tower Aloha Breeze Fan Logo
224 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
