My heating isn't working. Blue light is flashing. I have tried resetting it but the sounds of water gurgling through the boiler is quite loud and then the blue light starts flashing again. Never heard the water sound before. It was on and running okay and just 'went off'. Any suggestions....
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
Testimonial: "Thanks for the suggestion. Had to get a plumber out in the end. The water filter was blocked with sludge. He took that off and cleans it out. Got it working in no time - and on the bank holiday Monday - and only charged me £40.00!!"
Manual here
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/24i-junior-rsf-discontinued-aug-2007-literature
All these machines need 0,8 bar minimum pressure for one.
When significant drop of pressure call qualified repair man.
If this is not your regular work you are at mortal risk.
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
SOURCE: no heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
SOURCE: My boiler is not working, not heat, no hot water,
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
