Question about Car Audio & Video
How to replace rear speakers in a daewoo leganza 2002
  • 68 Answers
Open your boot, disconnect the wires from the terminals, unscrew the speaker. Remove the speakers. If you're upgrading from 6x6s to 6x9s and the whole is too small you will need to mount them on spacers. Screw the new speakers down from inside the car. You will need to wire the wires in the same configuration as your old speakers.
Posted on Aug 05, 2009
Fuel pump problem with a 2002 Daewoo Lanos
Why would you ever buy a used part for
any vehicle repair,especially a fuel pump.
Must be in some back water part of the world
Nov 28, 2012 | 2002 Daewoo Lanos
Hi My Name is Yessy, I removed my battery from my 2002 Daewoo Leganza.. And now my Car Radio doesnt work & its asking for a four digit Code!!
hi yessy your car have a radio code its mean anti theaf system.now you should need a help from your nearest daewoo dealer.they need your vin number to found your securety code ok
Jul 13, 2011 | 2002 Daewoo Leganza
What is the torque for a rear wheel hub assembly on a 2002 Daewoo Leganza?
caulking nuts 285 ft lbs.
knuckle to strut nuts 120 ft lbs.
strut mount to body nuts 45 ft lbs.
Jun 13, 2011 | 2002 Daewoo Leganza
My deforter from rear window not work daewoo 2002 laganza 16-val 4 cilinder
check the fuse, and the relay under the hood, one is bound to be bad.
Dec 04, 2010 | 2002 Daewoo Leganza
Torque spec for 2002 daewoo leganza for half shaft nut
THE LEGANZA MODELS TIGHTEN THE HALF SHAFT NUT TO 111 - 155 FT LBS .LOOSEN THE NUT RETIGHTEN TO 37 FT LBS.RETIGHTEN AN ADDITIONAL 60 DEGREES.STAKE THE NUT WITH A PUNCH AND HAMMER.THE NUT WILL NOT BE LOCKED IN PLACE UNTIL THE NUT HAS BEEN STAKED.
May 13, 2010 | 2002 Daewoo Leganza
Want to know where the oxygen sensor to my 2002 daewoo leganza is would like to replace it myself
THE O2 SENSOR IS EITHER IN THE EXHAUST MANIFOLD OR THE EXHAUST HEAD PIPE OF THE EXHAUST MANIFOLD, IT IS ABOUT THE SIZE OF A LARGE JUMBO MAGIC MARKER.
Dec 28, 2009 | 2002 Daewoo Leganza
Trying to replace timing belt
http://www.mvreader.com/multiview/dayco/zoom.php?zoom_item=C0000B&l=n&catalog=auto&category=2
This is a Direct Link to the Belt Routing Diagram for your Car. Please Rate My Response! Thanks!
Feb 04, 2009 | 2002 Daewoo Leganza
Heater in 2002 daewoo leganza not working
try replacing the thermostat, they're cheap. or test it if you want to. Ask and I will tell you how to do it. the only other thing it could be is, there are doors that open and close in the duct work, some are electric, some are vacuum. it depends on the car. thats a little harder to fix and I don't know about that particular car.
hope this helps
Jan 17, 2009 | 2002 Daewoo Leganza
2002 Daewoo Leganza help
It has a single din radio that can be purchased anywhere for under a hundred bucks. Check the antenna connection. Window regulators can be nought from Dr. auto parts. Go on ebay they go for about 40 bucks. Frank Kent Daewoo in Fort Worth Texas has the largest supply of Daewoo parts.
Good Luck
Nov 19, 2008 | 2002 Daewoo Leganza
Car Audio & Video Logo
380 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
