Question about Motorola Mobility RAZR V3i Cellular Phone
V3i as modem
Hi
i am able to connect the v3i to the computer with bluetooth and use as modem, can i bypass the bluetooth and connect the v3i to the computer with USB cable and connect to internet??
thanks
  • nitesh_nist Nov 23, 2007
    in the phone there is fax option
    how to utilize it
  • sliderule Nov 30, 2007
    Hi
    Thanks, i did that and system now connects to internet, but curiously i cannot send a fax using the USB cable, fax works fine with Bluetooth. any idea's as to why this could be??
    Thanks again
  • 25 Answers
You need to install usb driver for motorolla v 3i and create a dial up connection.
Download usb driver for motorolla v3i from this link
http://technosom.in/motorolla-razr-maxx-usb-drivers/
Posted on Oct 11, 2012
  • 35 Answers
Yep simply attach the cable start your motorola ponetools and tada you are done
Posted on Nov 27, 2007
Im trying to use PDAnet with bluetooth I have the bluetooth card installed on my laptop tuning vista, and it has an error that says that I need to install the bluetooth software for the phone, and I've...
Make sure you have bluetooth on on both, and that you are connected via bluetooth to your computer.
Turn on pda net on your DI and enable bluetooth dun.
Now go to your bluetooth settings on your computer and double click on your device, a new service should pop up allowing you to enable dun/modem and select that.
right click on your di bluetooth connection on your computer and create a dial up modem.
select the generic bluetooth modem, not the pdanet modem.
Type 123 in the phone number and leave the username and password blank and click connect.
Now you can right click on your DI bluetooth icon on your computer and select connect to the modem connection you just created.
After using my DI as a modem over bluetooth there are a few things to consider.
1. yeah it works great.
2. Its a battery **** fest.
Constant 3g with constant bluetooth = constant battery draw.
I would still recommend using your pdanet via the usb cable, seeing as this will keep the battery level charged, as well as same speed!
Aug 29, 2011 | Motorola Mobility Droid X
How i access internet in linux rhel 4 by my motorazr v3i
But there is a software i would personally recommend to you.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
  1. connect to mobile devices by IR, bluetooth, USB Cable
  2. Send and receive files between computer and device
  3. Access Internet from Device by Dial Up Networking
  4. Browse files on Mobile device
  5. Mount the mobile device on a user specified mount point or communication port.
    Usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
  6. Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  7. ability to connect to any locked/unlocked USB Internet Modems (Zero Devices)
  8. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
Sakis3g Homepage may not specify anything about connecting a mobile phone to computer and using it as an Internet Modem, but trust me its possible. Meanwhile I'm posting this by using DUN with the help of this script.
  • Just Run the script
  • choose Connect
  • Select Bluetooth
  • It will search for a new bluetooth device
  • Once your phone is detected, Select it and press ok
  • when it asks for APN (Access Point Name) provide it
  • When it asks for user name and password, Provide it. If your service provider do not need any username and password to access internet , Don't just leave it as blank (Program doesn't accepts empty user name and password. you just press space and enter)
  • Once all necessary informations are entered program may simply closes. Don't worry your connection manager will show this new connection entry.
  • To Disconnect the connection , you can select Disconnect option in Sakis3g.
hope this will help you to solve your issue.
Feb 22, 2011 | Motorola Mobility RAZR V3i Cellular Phone
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Can I use my motorola v3i as a modem? I just want to know if it's possible. If it is, how?
Yes you can. It will be via data cable or bluetooth. Bluetooth is the best way. Buy a bluetooth dongle. You can found instruction with it. I recommend Bluesoleil software. You can get phone configuration via your service provider. Keep posting. Let me know.
Feb 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
V3i as bluetooth modem
update the firmware then try again
Aug 25, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Use as phone modem for my laptop
go to ur settings..connections....USB settings....storage device or modem option...select the required and proceed..all the best
Thanks for using Fixya
Aug 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to connect motorola v3i as a modem to my laptop????
first contact your service provider and get the data package for using your phone as a modem.
then if that doesn't work
contact sony - hp and they might have to hange some settings.
Aug 05, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i phone tool free download
what I need to know is where can i get free download for Motorola V3i phone tools to use my phone as a modem. Thanks. Richard.
Jul 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Connection problem pc to moto v3i
hi, please enter any number say for example, 22
then on the other device when it asks for the pairing code enter the same number ie. 22.
hope this will solve ur problem
Jun 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
