Question about Sony Playstation 3 (PS3) Console
On startup screen remains black but power is on with green light. Tried resetting graphics (with two beeps!) tried both MSDI and normal cabling. Appreciate any help.
    Novelist:
  • 112 Answers
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i afrikaans BUT PLZZZ RATE ME
Posted on Dec 23, 2009
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Nov 24, 2013 | HP Pavilion Computers & Internet
Black screen at startup
It sounds like the graphics card or on board graphics is causing the issue, as the external monitor is not working either. Hopefully its a graphics card which can be replaced easily, or there is an expansion slot for a graphics card to be added.
One thing you could try is resetting the CMOS by removing the battery from the motherboard and leaving for ten minutes. Replace the battery and try booting.
Mar 14, 2012 | ASUS Computers & Internet
Optiquest q20wb LCD has black screen & green power light flashing
Hi Rickyknows2,
If you are not hearing any beep I assume you are having problem with your video so, please ...
- open your PC and check whether your video card is well placed (sometimes it looks fine but you never know) remove it and put it back.
- If you used to remove often the cable from the PC, it might be that the pins from the monitor cable are even broke... please check.
- try to find another video card and replace it just to make sure its the video ...
- last... reset the bios (but I doubt that this is your problem)
chsers ..
May 03, 2010 | ViewSonic OptiQuest Monitor
Will not come on...green light blinks showing power, but screen remains black...have tried all resets, hooked up different computers to it etc...
It's possibly the cable/plug points. I leave the vga plug unscrewed so that the computer is easy to move around and I sometimes have problems with the screen not coming on. Try a different cable.
Mar 09, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
Computer does not boot
After replug the graphic card and switch on the pc & install back the graphic ... The power button remains green but the screen is black. ... From what i have noticed there is probably some issue with the thermal cutout ... Lights light up, Drive sounds as if working,
Jun 19, 2009 | Acer Aspire 1691WLMi Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
No graphics on monitor whatsoever, screen completley blank
i think there is a problem with your system's hardware.. check whether your MOBO or your processor.. computers that doesn't startup and has no beep has defective or burned CPU or motherboard
Apr 18, 2009 | Foxconn 661FXME Motherboard
No video output from my computer.
Are you using an ON-board graphics adapter or a separate VIDEO CARD? Some motherboards lets you set the video output to "DISABLE ONBOARD GRAPHICS" if you have installed a video card (BIOS). You may have plugged the monitor cable to the onboard D-sub connection instead of using the Video Card D-sub connector.
Normally a flashing green power light means the input it receives from the video output is too much. You may have set the resolution too high or the bit depth too high. Consult the monitor manual on the rates it can handle. To be safe, try starting the computer on safe mode just to check if it is indeed the problem. If it boots properly and you can see your desktop, then there's a chance that the setting was too much for the monitor to handle.
Hope this gives you an idea.
Mar 15, 2009 | SAMTRON 94B 19 inch LCD Monitor
Hang at startup (BIOS)
Yes laptops can work without battery.
If the laptop is hanging on Dell logo and entering into BIOS then normally it is HDD issue but you have already checked without HDD so might be it is RAM or Board issue.
You can check with PC 133.
Please check your Laptop with minimal boot once (by removing all external hardwares like modem,tv tuner or graphics if any) and if you are geting the display one of the devices is causing the issue whch could be diagnosed by connecting one by one.
Feb 09, 2009 | Dell Inspiron 2500 Notebook
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
