Question about Nikon D60 Digital Camera
What is night mode on a Nikon d60. How do I turn it on and off?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Night mode?
Do you mean Night Portrait mode? Select it by turning the mode dial to the appropriate icon, deselect it by turning the mode dial to some other mode.
Do you mean flash? It pops up automatically in the point&shoot modes (except for Sports, Landscape, and NoFlash). You have to pop it up in PSAM modes.
Posted on Dec 22, 2009
4 Suggested Answers
Steve5
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
SOURCE: My Nikon D60 flash has
My D60 flash problem was that the flash would pop up, but would not flash. The release lever would keep "clicking"...it did no know that the flash was up. Since I was told that the min cost of sending it to Nikon for repair was $250, I downloaded a repair/service manual for the D60 from http://www.tradebit.com/filedetail.php/9029672-nikon-d60-service-repair-manual ($8.99)
This manual gives a step by step assembly and disassembly of the camera.
I actually lucked up and fixed my problem...
Problem Descripton/Solution (short version):
There was a tiny plastic collar at the flash hinge that got pushed back into the camera. This collar served to close a couple of contacts. I stuck a home made wire/double hook tool into the hinge clearance hole and pulled the collar out and snapped it back into place.
Problem Description/Solution (LONG version)
WARNINGS (based on experience)
1. Yes, the flash will still shock the **** out of you..even with the battery out. You will smell burnt hair/flesh.
2. Be careful of the tiny contact leaf springs. They are hard to bend back into the correct position.
3. The #00 screws are easy to strip out. Apply firm pressure, turn slowly, and make sure screw driver is aligned properly.
4. Proceed at own risk (to camera). Make sure your warranty really has run out. There are many ways to make things worse. You can back out now and buy an external flash.
All I had to take apart however was the top cover of the flash (two tiny screws on underside of the flash #00 philips head). I found that there are two tiny copper or gold "leaf spring" contacts that have to close to send a signal that the flash is up. These are located at the hinge where the flash wiring runs into a clearance hole into the camera (hole is a center of rotation of the flash). There is a small plasitc collar that fits into this clearance hole from inside the flash/camera base and through the flash housing at the pivot point and snaps into place via 2 plastic hooks or tabs (download/see repair manual). This collar serves to secure the flash housing to the base but also has a tiny pin sticking out that catches one of the contact leaf springs and closes the circuit. The problem is that this collar got knocked out of place and pushed back into the camera. I made a home made wire/double hook tool out of 22 gauge wire (see attached picture) and worked it into the clearance hole by pinching the hooks together and working it in. Go in above the flash wires (top of hole) since the wire path goes downward into the camera. With some work and luck I was able to hook the edge of the collar and pull it back out and snap it back in place.
I then put the flash cover back on and everything still seems to work.
My Hook Tool....
Posted on Oct 16, 2010
Ranglo
  • 1194 Answers
SOURCE: My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
Posted on Jan 25, 2011
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Nikon D60x Blurry night pictures
Try switching to Shutter Prority (S) with a fast shutter speed.If the light is not so good, up the iso to 800 to gain that faster shutter speed..
You do not say the lens in use ? if VR, make sure its switched on or use a tripod.
Hope this helps
Jun 22, 2009 | Nikon DSLR D60X D60 Body DSLR 10.2M pix...
Just bought Nikon D60. No matter what mode I use
looks like a viewfinder has an issue. If you have recently bought the thing just return it and get a new one. If not possible to replace , i recommend visiting Nikon authorised service center.
Could be something in the path of pentaprism.
Jun 13, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
Mar 08, 2009 | Nikon D60 Digital Camera with 18-55mm +...
I just got a D60 nikon , dose it have live view and how
The D60 does not have a live view mode. You have to use the viewfinder.
Nov 27, 2008 | Nikon Cameras
Will the Nikon SB600 speedlight work with the Nikon D60 Camera. All the instructions mention all the other Nikon camera's but not the D60. Will the auto flsh modes work with the auto modes of the camera
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Oct 01, 2008 | Nikon Cameras
Nikon D60 Digital Camera Logo
269 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
